D djspenserg Honorable Mar 3, 2012 13 0 10,510 Mar 5, 2012 #1 Could someone recommend a 650w+ Power supply for a FX-8120 that is between the $70-$100 price range?
Solution COLGeek Mar 5, 2012 I would recommend this one (even though rated for 620w) over any 650w PSU (in your price range): http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095 If you absolutely must have a 650w PSU, get this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020 Good luck!
COLGeek Cybernaut Moderator Apr 6, 2009 54,203 3,413 179,340 Mar 5, 2012 Solution #3 I would recommend this one (even though rated for 620w) over any 650w PSU (in your price range): http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095 If you absolutely must have a 650w PSU, get this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020 Good luck! Upvote 0 Downvote Solution
D djspenserg Honorable Mar 3, 2012 13 0 10,510 Mar 12, 2012 #4 Best answer selected by djspenserg. Upvote 0 Downvote
