Hi All,
It has been a few years since I've built a PC but I'm looking to do it again soon. I'll post as much info as I can and leave a few questions at the end. Thank you so much in advance!
Approximate Purchase Date: 12/01-12/23
Budget Range: $2,000-$2,500
System Usage from Most to Least Important: Gaming and Internet Browsing.
Parts Not Required: Mouse and Keyboard
Preferred Website(s) for Parts: Newegg and Xoxide.com
Country: United States
Parts Preferences:
Intel CPU
nVidia Graphics Card(s)
22+ inch monitor.
Overclocking: No
SLI or Crossfire: Yes / Maybe
Monitor Resolution: I don't know on this one
Additional Comments:
I'm trying to build the best rig I can without having to water cool it. It doesn't have to be top of the line but I'd like to get the most I can.
Parts:
Case:
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
Antec Lanboy air Blue Black / Blue ATX Mid Tower Computer Modular Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129093
Mobo:
ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131665
Video Card:
EVGA 015-P3-1580-AR GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130587
Power Supply:
COOLER MASTER Silent Pro RSA00-AMBAJ3-US 1000W ATX12V v2.3 / EPS12V v2.92 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171049
CPU:
Intel Core i7-990X Extreme Edition Gulftown 3.46GHz LGA 1366 130W Six-Core Desktop Processor BX80613I7990X
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115079
Memory:
CORSAIR Vengeance 24GB (6 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model CMZ24GX3M6A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145350
Monitor:
ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor 300 cd/m2 ASCR 20000:1 (1000:1) Built-in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236049
HD: ?
Questions/Comments:
Is the power supply I picked out too much? Should I go for something closer to 750-850?
I listed two cases. I *think* they would both work but is there are better choice?
I'm sort of lost on what hard drive to get. I don't need lots of space. I was thinking maybe a 300 gig. Any suggested brands?
I'm not devoted to the video card and memory. They seem like good choices though. I know that the most expensive pieces aren't always the best. Is the video card worth that much?
Thanks so much for you help!! Please let me know if additional info is needed.
-Brody
Parts Preferences:
Intel CPU
22+ inch monitor.
Overclocking: No
Parts:
Case:
Mobo:
Video Card:
Power Supply:
CPU:
Memory:
Monitor:
HD: ?
Questions/Comments:
-Brody
