The speed of processor 0 in group 0 is being limited by system firmwar
Error Report in Event Viewer:
The speed of processor 0 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 15 seconds since the last report.
The speed of processor 1 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 15 seconds since the last report.
The speed of processor 2 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 15 seconds since the last report.
The speed of processor 3 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 15 seconds since the last report.
System COnfig:
Dell Inspiron Laptop 15R
Intel i5 450M
4GB Ram
ATI Radeom HD 5470 1GB
What does this error message mean???
Please ask for any further information
5 answers Last reply
More about speed processor group limited system firmwar
  1. Sounds like it might related to a Power Saving option to extend battery life.
    Does it continue when you have the laptop plugged into AC power?
    Have you tried changing the Power Options to High Performance?
  2. I am using it with AC plugged in. And it is in balanced. Have changed it to High performance. WIll update regarding the re-occurrence of the error.
  3. It's proably a good idea to check the CPU temps at idle and under a full load.
    Just in case it's an over temp condition causing the CPU to slow down.
    HWMonitor
    http://www.cpuid.com/softwares/hwmonitor.html
  4. I had this problem when using an aftermarket power supply with my latop. I have the i7 Q720 which is rated at 1.6GHz up to 2.4 Ghz. When plugged in it would be limited to 1.44 Ghz max because the computer did not like the power supply, even though it had the exact same ratings as my original one. If all else fails I would see if that is the culprit. As soon as I unplug it and run on battery or use the right plug it goes back to normal.
    I am having this same issue with my Dell XPS Studio where it will run nice at 2.1-2.5 for just a bit then it begins to drop to 1.44, then 1.31 and sometimes 0.91 and will not recover speeds, any other advice on this issue would be great!
CPUs Performance Firmware Processors
