Currently I have a BT Home Hub 2.0 (the black one) which has one wired computer and multiple wireless computers connected to it. I have tried connecting my pc to this hub using a long Ethernet wire. However, when I plugged this wire into my pc, it would continue to say "network cable unplugged". I have also tried a crossover cable and multiple network cards to no avail.
Next, I set up a Belkin G Mimo Router in my room, connect the Ethernet wire from the BT Hub and then connect another one from the new Belkin router into my pc. With this set-up, I could access the internet from the BT Hub downstairs.
However, this setup will no longer work and Im not sure on the settings that I have used on the Belkin Router.
The IP address of the BT Hub is 192.168.1.254 using a range of IP's of 192.168.1.64 to 192.168.1.237.
The Belkin's default IP address is 192.168.2.1 but have changed this to 192.168.1.253 and tried setting it as an Access Point but when I connect to it, I cannot ping the BT Hub suggesting I haven't set it up correctly.
Both, use the subnet mask of 255.255.255.0.
Does anyone have any suggestions of how to configure the router correctly so I can access the BT Home Hub's internet through the router or the Ethernet.
Thanks
Thanks
