2 6pin PCI-e connections on one cable?
Last response: in Components
- 2 6pin PCI-e connections on one cable? - Forum
- PCIe cable splits into 2 6pin cables - is it ok to use it? - Tech Support
- HD 6850 Toxic OC and PSU (500w) only got one PCIe 6-pin cable? - Forum
- I want to buy a Sapphire R9 270X Vapor-X 2GB GDDR5 but my PSU has only one 6pin PCIe - Tech Support
- can i turn a sata 2 cable into a pcie 6pin power cable for a gpu? - Tech Support
- Need 2 6pin pcie connections for gpu Radeon HD6870 Forum
- PCI-E 6-pin to 2-Molex Power Y-Adapter Cable Keeps burning Forum
- Using two seperate PCI-E on my 280x's. One with 8pin and the second with 6pin per gu (2x PCI-E per GPU) solution
- 2 PCIe 6pin connectors on one cord. Forum
- SolvedDoes a dual link dvi cable actually have 2 dvi connections at one end? solution
- SolvedPCI-E 6-pin male to male cable? solution
- 2 PCI-E 6-pin connecters malarky Forum
- SolvedPowering my R9 270X with one PCIE 6-pin and a dual molex to PCIE 6-pin? solution
- SolvedASUS Strix 970: 2x 6-pin pci-e to 1x 8-pin pci-e solution
- Solved650ti Boost 2x4pin molex to 6pin pci-e solution
- PSU with one 6-pin PCI-E to two 6-pin solution
- Solvedhow to connect the Corsair VS550 550 Watt PSU having 6pin pci cable to zotac gtx 650 ti graphics card????? solution
- SolvedDoes an 8pin to 6pin work the same as a 6+2pin pci express cable? solution
- SolvedGTX 650 Ti Boost DCU-OC2, can it run without 6-Pin power cable? solution
- Solved2 Seperate PCIe cables on one GPU. solution
- More resources
Read discussions in other Components categories
