Solved
Will all my parts work well together?
Last response: in Systems
This is my first pc build from the ground up and i'm just wondering if everything i have chosen will work together well, or if there are any suggestions to improve.
gigabyte 990fxa ud3 motherboard
phenom II x4 965 BE
Mushkin enhanced redline 1600 ddr3 8bg
western digital caviar black 1tb HD
Ocz zx series 850w 80plus gold modular psu
also a cd/dvd burner and a gtx 570 video card. the case will be a cooler master 932 black edition
More about : parts work
Best solution
Homebuilt system Master
Definitely not a bad build at all. I just got that same board, I'm planning to install it on Monday.
For optical - any $20 drive will do (although I hate the bulk Asus burners), and for NVIDIA - definitely go with EVGA.
Related ressources
roald said:
The only thing i'd add is an SSD, as long as it's in the budget. Shiny new systems also deserve a shiny new responsive feel to your OS and programs.
I did some looking and decided you were right so i added a 80gb ssd just for my operating system. I also changed the psu to the same line of psu's but upgraded to the 1000w version and changed the video cards to the gtx 580 classified in sli
Homebuilt system Expert
For just an OS, 30 to 40GB is fine.
I would preferable go for a 60GB SSD.
It will fit your OS, along with other data.
What is your entire budget?
There are many changes you should make if you are getting a pair of high-end cards.
I definitely want it to be under 2000, what do you suggest?
Ask the community
