I recently purchased a Pioneer VSX 821 K receiver:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117397 [newegg.com]
I have gotten movies to play correctly using Dolby Digital, but I cannot figure out how to get Dolby Digital in BF3, at the moment I am only able to get Dolby Pro Logic II to work, which isn't good enough because it simply makes a stereo signal sound like 5.1, it's not true surround sound.
Here is how I have my system hooked up. I have a Turtle Beach Montego DDL Soundcard(http://www.newegg.com/Product/Product.aspx?Item=N82E16829118006) [newegg.com] in my PC, along with the motherboard's integrated optical port. I have tried connecting both to the receiver via Optical cable(optical OUT port on soundcard and optical port on motherboard), but no luck. I have also made sure that when you go to audio settings in-game, it's set to Home Cinema, and Stereo Enhance(or w/e it's called) is off. But I am unable to select or enable Dolby Digital on my receiver.
From what I understand, an optical cable should be able to transfer a Dolby Digital signal, because it can for DVD's and movies. Eventually I will run the sound from my video card with HDMI, but my current video card does not have HDMI so until I upgrade that, I hope to get this working.
Any suggestions?
Any suggestions?
