Solved
Seeking compatible power supply
Hello, I have an HP p6510y computer. I'm looking to upgrade with a new power supply. Unfortunately I can't seem to find any information on which power supplies are compatible with what I have. I'm looking to upgrade to 500 - 600 watts, depending on price. Which specific power supplies will fit in my PC?
4 answers Last reply Best Answer
More about seeking compatible power supply
  1. Best answer
    The HP Pavilion p6510y Desktop PC uses an ATX (a.k.a. PS2) Form Factor Power Supply.
    Standard ATX12V Power Supply Design specifications:
    Dimensions:
    150mm W x 86mm H x 140mm D
    or
    5.9" W x 3.4" H x 5.5" D
    The only dimension that will vary with power supply capacity is the Depth.
    Measure the depth of your current power supply and look at the depth dimension of the power supply you want to purchase to make sure it will fit in the HP Pavilion p6510y Desktop PC's case and not interfere with the cables connected to the back of the CD/DVD Optical drive.
    Select from top tier brands like Antec, Corsair, Enermax, Seasonic, XFX.
  2. Thank you!
  3. Best answer selected by Scarecrow237.
Power Supplies Hewlett Packard Compatibility Components Product
