I have an intel i950 processor. I would like to know if you are considering building a gaming computer what motherboard would you select for this processor and why.
Here is the processor: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115211&Tpk=intel%20i7%20950
Not sure if this would help but I decided to fill out this form if it would help get an answer for me.
Any help is most appreciated as always.
APPROXIMATE PURCHASE DATE: Sometime this year with in the next few months.
BUDGET RANGE: $1000 to $2000
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT:
This is what I would like to do on this system
High End Graphic PC Gaming
Microsoft Word, Powerpoint, Access, Excel
Regular Email (Example: google, yahoo, etc)
Downloading/Uploading Streaming Video
Music Player
Computer Programming (Visual Basic, C++, Java, Perl, HTML/XHTML)
Games to be played on System: Counterstrike 1.5, Counterstrike Source, Bad Company 2 & 3, Diablo 3, Any high graphic end first person shooter game that comes out later in future. Would like to make certain that this system will be able to play any future games.
Would like Raid capability.
PARTS NOT REQUIRED: CPU, Monitor, keyboard, mouse, speaker, Operating System (Win 98, XP, Windows 7, Fedora), HAFX computer case
PARTS REQUIRED:
Motherboard
Graphics Card
Memory
Hard Drive
Power Supply
Heat Sink
DVD/CD Burner
PREFERRED WEBSITE(S) FOR PARTS: www.canadacomputers.com - Or any other website that has good prices to order from for Canadian dollar.
COUNTRY OF ORIGIN: Canada, Ontario
PARTS PREFERENCES: N/A
OVERCLOCKING: Yes
SLI OR CROSSFIRE: Yes (Not needed but good in the future)
MONITOR RESOLUTION: Using a SyncMaster 931w with 2000:1 Dynamic contrast. Using windows XP Pro with the following settings at 1152 x 864
ADDITIONAL COMMENTS:
Computer needs to be able to do multi-tasking with multiple windows open without freezing or clogging.
Ablility to ALT TAB out quickly launch or access programs
Computer Fans Need to be quiet (Friend has a computer and sounds like a vacuum cleaner/airplane combo when turned on - don't need this)
Low to moderate power consumption if possible
Something that will suit my needs and will continue on in future for quite sometime.
Music Player
PARTS REQUIRED:
Motherboard
Graphics Card
Memory
Hard Drive
Power Supply
Heat Sink
DVD/CD Burner
OVERCLOCKING: Yes
