Hello all,
So as the name suggests, I'm looking to build a "productive" system for my wife. By "productive", I mean she runs a small business which requires her to use the CS5 suite (Photoshop, Indesign, Illustrator, Lightroom, and Dreamweaver) all extensively.
I'm not going to tell you what she's using right now because it is downright shameful, but she finally came to her senses and is allowing me to start looking for parts. My experience in building rigs has always been tailored more towards gaming and so now that I have to shift gears, I have more questions than answers at this point.
So, using the sticky here is what I'm looking for:
Approximate Purchase Date: within a month's time.
Budget Range: as low as feasible, preferably <$500 USD (with the understanding that this might not be the most effective range for performance/cost ratio)
System Usage from Most to Least Important: Primary programs she would use: Photoshop, Indesign, Illustrator, Lightroom, and Dreamweaver
Parts Not Required: keyboard, mouse, speakers, monitor, case, possibly hard disk (is currently using a Samsung HD642JJ 640GB 7200),
Preferred Website(s) for Parts: newegg
Country: USA
Parts Preferences: Looking for a processor, RAM (both amount and speed), motherboard, PSU.
Overclocking: Yes/Maybe
SLI or Crossfire: No
Monitor Resolution: Single monitor @1920x1080
Additional Comments: As mentioned, looking for a "productive" setup. She is currently running a 8800GT but I have a spare 4890 I was planning on using for her. My question is would she benefit from the gfx upgrade for the programs she uses? I know that her photoshop projects get quite large and complex but not sure if the 4890 would be overkill since she's not doing a whole lot of 3D rendering? Though the extra VRAM and speeds would most likely help, if the benefit of the 4890 over the 8800GT wouldn't be quite necessary, I could sell it and use the money towards other parts.
So yeah, there is/are my question(s). To sum it all up, I'm looking for the cheapest recommendation for a processor, RAM, mobo, PSU, , if the current Samsung 7200rpm 640GB, is sufficient, and which of the two, the 4890 or 8800GT, would best serve her needs and our financial situation.
To give you an idea of what I found/was thinking, I looked at a Core i3-2120, a H61 full ATX mobo, 8GBs DDR-1333, and a rosewill 630w 50A-12v PSU all for <$300 w/shipping. Thank you all for taking the time to read this and for any suggestions/comments/criticisms!
Nik
Country: USA
Nik
