Hello again, I plan for this to be my main gaming PC\workstation for projects and video\photo manipulation and transformation. Although $1000 is not a lot of money when it comes to a mid to high end PC, I have tried to be as thorough as possible regarding the specs of this new build, including hyperlinks to the products on Newegg.com(my preferred merchant site).
Approximate Purchase Date: Next year (2012)
Budget Range: approx. $1,000 Before rebate
System Usage from Most to Least Important: Gaming, HD Video veiwing, Homework projects, Photo rendurring, surfing the web
Overclocking: This is my first custom build, so probably not.
SLI or Crossfire: Maybe
Monitor Resolution: 1440x900(I plan on getting a 1920 by 1200 soon after)
And I will be purchasing all parts through Newegg.com.
Now for the Parts List:
Umm... I could have left something out, so please don't hesitate to let me know. Also, would it be worth it to buy the FX-6100 or should I stick with the Phenom II x6 1100t? Pros and cons?
Thanks!
P.S. I hope I put this in the right section.
Mobo: GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=r9ms3i2vkboh (159.99)
CPU: AMD Phenom II X4 970 Black Edition Deneb 3.5GHz Socket AM3 125W Quad-Core Desktop Processor HDZ970FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103894 ($139.99)
CPU cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R1 120mm Sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 ($34.99)
GPU: XFX HD-687A-ZDFC Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150521 ($194.99)
Case: COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&Tpk=CoolerMaster%20HAF%20912 ($68.99)
PSU: Antec EarthWatts Series EA-750 Green 750W ATX12V v2.3 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Continuous Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371051 ($94.99)
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9R
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233180 ($58.99)
Optical Drive: LITE-ON Dual Layer DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289 ($19.99)
HDD: Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767 ($84.99)
All that sums up to $857.91
Thanks!
