135mm replacement power supply cooling fan
HELP!!
Looking for135mm replacement cooling fan for 700W OCZ MOD XSream Pro.( Have two broken Blades).
Thanks!
4 answers Last reply
More about 135mm replacement power supply cooling
  1. http://www.newegg.com/Product/Product.aspx?Item=N82E16835185163
    that is a nice quiet decent air flow fan.
    135mm size is not common in PC cooling so your choices are limited.
  2. there is an issue with that fan its very slow and has a pretty low cfm rating. not only that its single speed...
    http://www.play.com/PC/PCs/4-/28775984/Zalman-135mm-Quiet-Cooling-Fan/Product.html?_%24ja=tsid:11518%7Ccat:28775984%7Cprd:28775984 this on the other hand would be a great option as long as you can mount it...
    i know it uses 120mm mountings but 4 cable ties would sort that out...
    also try the ocz forums they have reps there that will tell you if you can buy a replacement fan off them directly...
  3. I don't know how the blades got broken but are you still using the PSU? Is the PSU still in warranty? Once you break that seal on the case the warranty ends. If you are still using it, fan failure is inevitable due to imbalance. Maybe you could return it to the mfg. for warranty or repair.
Power Supplies Cooling OCZ Fan Components Product
