SLI and sound card?
I have a quick question that is bothering me quite a lot, I am planning on having two gigabyte gtx 670's in sli on a Gigabyte SKT-1155 Z77X-UD5H Motherboard.
The problem is that i also want to fit in a asus xonar dx and a tp link wlan card; would i have enough space on the motherboard?
2 answers Last reply
More about sound card
  1. When I look for those cards and MB, the 2nd PCIx1 will be block by the 670. You have to install the sound card either on the 1st (closed the CPU) slot and the 3rd slot.
  2. install the sound card in the first x1 slot then use the two slots below for the sli config
Motherboards SLI Gigabyte
