Approximate Purchase Date: December 2011-January 2012
Budget Range: $1200-$1500 (a little wiggle room here)
System Usage from Most to Least Important: Gaming (skyrim, FPS games, guild wars 2, etc), watching movies, maybe some music editing
Parts Not Required: DVD drive, HDD (using a Seagate 720GB 7200rpm, 3.0Gb/s drive from my old HP desktop), mouse, keyboard, speakers, OS
Preferred Website(s) for Parts: Newegg, NCIX
Country: Canada
Parts Preferences: Intel, NVIDIA
Overclocking: Yes, definitely on the GPU, and probably on the CPU
SLI or Crossfire: Not for now, but would like the option down the road
Monitor Resolution: 1920x1080
Additional Comments: Here's what I'm looking at so far, already bought the case and CPU cooler (included in budget):
Case: Antec DF-85 Full-tower - I already bought this since it was a deal - $149.99 with free shipping. Considering buying an optional fan for the side panel...thoughts?
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811129087
Mobo: ASUS P8 Z68-V Pro - not sure if this is overkill
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131730
CPU: Intel Core i5-2500k Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) - seems to be the standard for a gaming CPU
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115072
CPU Cooler: Cooler Master Hyper 212 Plus - also already bought this when it was on sale
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103065
PSU: CORSAIR Enthusiast Series CMPSU-850TX 850W ATX12V - I know it's a quality PSU, not sure if I want to go with something cheaper on such an important part, but open to ideas
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139009
Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231314
GPU: EVGA GeForce GTX 570 - I heard the 600 series is coming out in the next month or so. Would it be better to wait for those?
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130593
Monitor: Replacing my 21.6", 1680x1050 Samsung monitor (though I will likely use it as a second monitor for all non-gaming applications). I would like something at least 24" in size, 1920x1080, 2ms is ideal. I guess I would like an LED backlight, but I'm not set on the idea...what are some of the advantages/disadvantages? I'm also considering waiting until boxing week to get the monitor, since I've heard the deals are pretty good. A quality brand like ASUS or Samsung would be nice...something in the $250 or less range.
Any input/suggestions are much appreciated!
Country: Canada
