Motherboard and Component help.
January 12, 2013 3:37:57 PM
hey guys, i would like to know if these hardware peripherals would work together. The most important thing i'd like to know is if the motherboard would fit into this case... i've already checked sizes in comparison to the last Motherboard, and by the sounds of it, the new one will be smaller than the last. Thanks for any Help in advance.
Preferred Contact - chaoticmonkeh@googlemail.com Thanks Again.
Case - Evesham Axis AK47 (OLD CASE :/  )
PSU - Be Quiet E9 StraightPower 400W PSU
Motherboard - Asus M5A78L-M/USB3 AMD Socket AM3+ 8 Channel HD Audio mATX Motherboard
Central Processor Unit - AMD FX-4 4100 Black Edition 4 Core 3.6Ghz Socket AM3+ 8MB L3 Cache Retail Boxed Processor
Memory (RAM) - G-Skill 4GB DDR3 1333MHz Memory Module (x2 of these)
Storage - I will be using my old Serial Sata HDD for this, 200GB as it has my O/S Etc..
Video Card - Sapphire HD 6570 2GB DDR3 DVI VGA HDMI PCI-E Graphics Card
Optical Drive - Liteon IHES112-115 12x BD-ROM with DVD±RW DL & RAM SATA Optical Drive - (Blu-Ray)
Optional two fans -
Fan 1 - CoolerMaster 120mm Sickleflow Fan - Blue LED ( For the Back of Case )
Fan 2 - Arctic Cooling Arctic 80mm F8 Case Fan ( Front of Case )
If somebody(s) could help me with this then i would be greatly appreciative. :D
More about : motherboard component
