Hello,I have a Gigabyte Radeon 650, I've been running two monitors for a while now, both asus 24 inch, both connected via dvi.
I just got an asus 27 that I would like to run as well, it has a display port, and I have a display port cable hooked to the 6850.
I cannot view both dvi outputs at the same time. I can go into catalyst control center, and choose one or the other, and get either to work, but not at the same time unless I disable the display port monitor. SO, I can get any two to work, but not all three.
what can I do?
what can I do?
