Hi guys, I have just about gathered all my components together, I just need help with a few more. I will list what I have, what is on order and what I need to finish my build. Thanks ahead of time for advice and you consideration.
All constructive criticism is welcome. The reason I am posting is because I do need just a bit of guidence on the last few components. I do know some of the system would be overkill as I had posted on another thread. That is just the way I decided to go and wish to finish it up in that manner.
Parts IN HAND:
PROCESSOR...INTEL 2600K
MOTHERBOARD...ASUS MAXIMUS EXTREME Z Z68
HARD DRIVE...HITACHI DESKSTAR 7K1000.D
SSD...KINGSTON HYPER X 240GB
PARTS ORDERED AND ON THE WAY...
CASE...SILVERSTONE FORTRESS SERIES FT028...(DECIDED NOT TO USE A STORM SNIPER CASE I HAD ALREADY PURCHASED)
PARTS STILL FINALIZING...
POWER SUPPLY...SEASONIC PLATINUM 1000...PLENTY OF HEADROOM FOR LATER AND BUILT LIKE A TANK, NO WORRIES DOWN THE ROAD.
OPTICAL...LITE ON iHAS424-98 DVD WRITER
OPTICAL...LG WH12LS38 BLU RAY BURNER
HERE IS MY TWO COMPATABILITY ISSUES...WHICH MEMORY AND CPU COOLER TO GET. I WANT TO RUN AIR FOR NOW. I WILL BE OVERCLOCKING BY THE WAY. I HAVE READ THAT THERE IS NOT MUCH DIFFERENCE BETWEEN MEMORY SPEEDS ABOVE 1600. BUT THERE DOES SEEM TO BE A BIT OF A BUMP AT 1833. SO WHICH RAM TO GET FROM THESE TWO...
G SKILL SNIPER SERIES 8GB KIT...CAS 7 1.6V
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231459
OR
G SKILL SNIPER SERIES 8GB KIT...CAS 9 1.5V
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
AND FINALLY ONCE THE RAM IS PICKED, WHICH AIR COOLER TO USE?...I HAVE BEEN LOOKING AT THE ZALMAN SERIES OF COOLERS. BUT, I HAVE NOT BEEN ABLE TO DETERMINE WHAT COOLER WOULD BE COMPATABLE WITH THIS MOBO AND THESE RAM...ANY HELP WOULD BE GREAT.
MY CASE WILL BE HERE WEDNESDAY AND I WANT TO GET THE REST OF THIS STUFF ORDERED TONIGHT OR TOMORROW. ONCE I GET EVERYTHING TOGETHER, I WILL PUT A POST UP WITH SOME PICS HOPEFULLY ONCE I GET GOING ON THE BUILD. THANKS FOR THE HELP GUYS, I APPRECIATE IT.
Parts IN HAND:
OR
