Hi every one
I have a couple question about case fan and power supply
the case fan power connection will connect to the power supply or on board power fan which way is better?
Power Supply OCZ 850W mounting in cooler master haf
I got a little confuse about power supply fan face up or face down?
Face Down at the bottom of the case for suck the cool air from out side to in side of the power supply to keep the power supply cooler. Is that right.
Face up at the bottom of the case for sucking the hot air in side of the case out ? is that correct.
which way is better.
thanks
thanks
