Home Network problem still unsolved :-(
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.customize (More info?)
XP Athlon is host.
ME Intel is guest.
Host can read all shared files and folders on guest
computer.
Guest can connect to the net via the host ADSL
connection - but when trying to access files and folders
I get a "You dont have permission to access Athlon"
Both computers have same username and password.
Can someone please help?
Thanks
Ron
ron wrote:
> XP Athlon is host.
> ME Intel is guest.
> computer.
> Thanks
> Ron
Well, the first thing that comes to mind is, have you shared
any folders on host? You must first share something on the
host before the client ME will be able to see them. Select
any folder you want to share, RMB on that item and enable
sharing. Post back if that is not a solution.
gm
>-----Original Message-----
>ron wrote:
>> XP Athlon is host.
>> ME Intel is guest.
>> computer.
folders
>> Thanks
>> Ron
shared
the
Select
>gm
>Sharing is enabled - poblem has not gone away!
more help please gm
Ron
> >ron wrote:
> >> XP Athlon is host.
> >> ME Intel is guest.
> >> computer.
> folders
> >> Thanks
> >> Ron
> shared
> the
> Select
> >gm
> more help please gm
> Ron
"Sharing" requires 2 things (at least), Sharing enabled, and
something shared.
First you must have "sharing enabled" in the network
properties. RMB on My Network Places and select properties.
You should see there Local Network Connections. RMB on Local
Network Connections and select properties, there will be a
list which includes File and Printer Sharing. That will make
"sharing enabled". I suspect this is already set or you would
not see the client from the host either.
Second you have to share a folder. Select any folder, "Shared
Documents" is a good choice. RMB on that and select Sharing
and Security. Once there, "Share this folder on the network"
most also be checked.
When you say "sharing is enabled", are you saying that both of
these setups have been done?
gm
Related ressources
New THing to do is to enable the guest account on the host XP system.
settings:control pannle: users select guest account and turn it on.. all
computers in a peer to peer network with xp use this guest account.
"gmnospam@nospam.xyz" wrote:
> > >ron wrote:
> > >> XP Athlon is host.
> > >> ME Intel is guest.
> > >> computer.
> > folders
> > >> Thanks
> > >> Ron
> > shared
> > the
> > Select
> > >gm
> > more help please gm
> > Ron
> something shared.
> gm
Hi guys
Guest account is turned on and sharing enabled in all
places mentioned. Still get an "unauthorised" message on
ME (guest)when trying to access files on host. Also guest
connects to the Net automatically on start up - can I
turn this facility off?
Thanks again
Ron
host XP system.
turn it on.. all
guest account.
>> > >ron wrote:
>> > >> XP Athlon is host.
>> > >> ME Intel is guest.
guest
>> > >> computer.
>> > folders
Athlon"
>> > >> Thanks
>> > >> Ron
you
>> > shared
something on
>> > the
>> > Select
enable
>> > >gm
>> > more help please gm
>> > Ron
enabled, and
>> something shared.
properties.
on Local
be a
will make
you would
folder, "Shared
Sharing
network"
both of
>> gm
Ron: Do you have identical account names on both computers? Must have this
as well.
"ron" <anonymous@discussions.microsoft.com> wrote in message
news:477401c48938$4cb3c440$a301280a@phx.gbl...
> Hi guys
> Thanks again
> Ron
> host XP system.
> turn it on.. all
> guest account.
> >> > >ron wrote:
> >> > >> XP Athlon is host.
> >> > >> ME Intel is guest.
> guest
> >> > >> computer.
> >> > folders
> Athlon"
> >> > >> Thanks
> >> > >> Ron
> you
> >> > shared
> something on
> >> > the
> >> > Select
> enable
> >> > >gm
> >> > more help please gm
> >> > Ron
> enabled, and
> >> something shared.
> properties.
> on Local
> be a
> will make
> you would
> folder, "Shared
> Sharing
> network"
> both of
> >> gm
Ask the community
