I've just finished putting together a newly built system:
ASUS P8 Z68-V Pro Motherboard
Intel i7-2600K Processor
Seasonic 750W Power Supply
Radeon HD 6950 Graphics Card
Omega Sound Card
16G DDR-3 RAM
I've made all the connections I think I need, when I turn the power supply on, the lights on the motherboard come on, but when I push the power button on the tower case, nothing happens. I've checked the connections to make sure everything's tight, but to no avail so far.
Ideas for a checklist of things I can check to start eliminating problems? Should I try to disconnect various components to see if I can just get the computer to boot?
Thanks for any input.
Omega Sound Card
16G DDR-3 RAM
