Approximate Purchase Date: Before Xmas this year
Budget Range: Approx $1500-2000
System Usage from Most to Least Important: Gaming
Parts Not Required: Monitor
Preferred Website(s) for Parts: http://www.umart.com.au/newindex2.phtml?bid=5
-NB: Would be open to other online companies based in Brisbane / Sunshine Coast if anybody knows one better than Umart
Country: Australia
Parts Preferences: Intel CPU, Midtower case
Overclocking: Not inititally, would be fun to tinker with later on down the track, especially if fps starts dropping with new release games
SLI or Crossfire: Yes
Monitor Resolution: Not 100% sure (Hasn't been used for a while - 22inch panasonic LCD, cost $500 when i got it in 2005)
Additional Comments: please NO window or bling, a nice standard case that hides a gaming monster would be preferred!
CPU: Intel Core i5 2500K Processor LGA1155 3.3GHz CPU ($230)
NB: no1 CPU for gaming?
CPU Cooler: No Idea, will an aftermarket cooler be needed if not overclocking? I could purchase this later on down the track if i decide to play with OC?
MOBO: ASRock Z68-EXTREME7-GEN3 Intel Z68/4x DDR3/D-Sub/HDMI/DVI/DP ($285)
NB: I want either this or a similar motherboard that is relatively future proof and xfire capable
GPU: 2x Sapphire ATI HD6950 2GB GDDR5 PCI-E ($574)
NB: Thoughts???
MEMORY: No idea, i'm pretty sure I need double-channel memory... I've seen good things and several people recommending the G.skill Ripjaws, but 1333,1600,1866,2133? How important is this? Is 8GB sufficient?
SSD: OCZ Agility 3 120G SATA3 SSD ($195)
NB: Cheaper than the revo series, i doubt that the speed difference would ever be that noticeable?
HHD: Seagate SATA3 1TB 7200RPM 32mb Cache ($139)
NB: I just need anything for a secondary storage drive, 1TB should be plenty as will be LAN connected to a media server with 6TB of space if needed. This was the cheapest 1TB drive I could find on umart.
Optical Drive: Asus DRW-24B3LT 24x DVDRW SATA LightScribe ($29)
NB: Something cheap, Blue ray is not needed (Have a PS3 already in room)... LIGHTSCRIBE!
CASE: Also, not much of an idea. I would like a mid-tower, something big enough to physically fit everything in with adequate cooling to prevent overheating. (It gets bloody hot over here...) Something sleek, no windows, LEDs, fan LEDs etc. Either all black or white preferably.
PSU: Anything adequate, is 750W minimum considering twin HD6950 GPUs?
Mouse and Keyboard: ?
NB: I've been out of the gaming circles for a long time, I would like something that works well without looking like the super crazy gaming setups.
Speakers: Something cheapish, I live in a unit so I can't crank the tunes anyway.
Cost currently = $1452.
Still need to decide on Memory, Case, PSU, Keyboard, Mouse, Speakers and whether aftermarket cooling is needed.
Comments more than welcome, assuming that I spend ~$400 on Case, PSU and Memory that puts me almost bang on the $2000 budget.
The aim of this system is to be future proof for approx 5 years, able to destroy games with ease. Hopefully its high-end enough...
Thanks in advance for any help you can give guys!!
Nathan.
Country: Australia
NB: Thoughts???
Nathan.
