Monitor with Horizonal/Vertical lines running through it
pidderr
6
I'm not really sure if I have selected the correct catergory/sub-catergory but I just bought a Acer Aspire X1420G computer. I already had a good monitor that worked fine with my old emachine but when I connected it to the acer I got hundreds of very thin horizonal/vertical lines running through it. The shape of the lines look very similar to the upper left corner of a picture frame. I have tried calibrating the colors, I bought a new cable cord and I can't seem to fix it. Can anyone tell me what I need to do? And Thanks in advance for any suggestions you have to offer...Pat
pidderr
6
If it's the graphics card, would the lines still appear on the monitor even with the cpu turned off? Because when the computer is off and I turn on the monitor you can still see the lines but with a black background.
