Closed Solved
What Graphics card (and possibly other hardware) should i add to my pc?
I have a Dell Inspiron 546, 6gb ram, amd anthlon II x3 425 processor, with win 7 64-bit, (and currently a gt9500 pci exp. card from sparkle in it). My monitor is a Haier 24'' and i run at 1920x1080 res. I was wondering what type of vid card i should buy, if i need a better motherboard, etc. and if i should get some other hardware for an extreme, top gaming pc. anybody who can help me out i would highly appreciate it. im looking for options due pricing (would appreciate it even more if somebody posted multiple cards/hardware so i can compare/see what i want to buy) thanks to all in advance.
5 answers Last reply Best Answer
More about what graphics card possibly hardware
  1. For an "extreme" gaming PC you'd probably want to ditch that thing altogether and build a new system to be honest. If you don't want to do that then I'd just get an HD6670 which will do quite well at low resolutions.
  2. What is your power supply ? Do you have a budget or ballpark amount that you would be willing to spend. To be perfectly honest with you if you want an extreme , top gaming Pc , then you should expect to spend about $2000 and that would be the bottom figure. Now if you want a gaming Pc , that will play all the games at high settings and get around 6ofps then you could end up spending less. It really is what you are trying to achieve with what you want to spend. other than the OS you have there are no extreme parts in your computer.
  3. Best answer
    COOLER MASTER HAF 932 Advanced RC-932-KKN5-GP Black Steel ATX Full Tower Compucase Case with USB 3.0, Black Interior and Four Fans-1x 230mm front RED LED fan, 1x 140mm rear fan, 1x 230mm top fan, and 1x 230mm side fan $159.99 and a $20 rebate---$139.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
    Antec High Current Gamer Series HCG-900 900W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply $129.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371050
    Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K $219.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
    ASUS P8Z68-V LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard $179.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131729
    CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C7R $109.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233219
    MSI N580GTX Lightning Xtreme Edition GeForce GTX 580 (Fermi) 3072MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card $594.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127589
    Corsair Force Series GT CSSD-F120GBGT-BK 2.5" 120GB SATA III Internal Solid State Drive (SSD) $204.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820233191
    Western Digital Caviar Black WD2002FAEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $149.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136792
    LG Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 10X BD-ROM 4MB Cache SATA Super Multi Blue Internal SATA 12x Blu-ray Disc Rewriter WH12LS38 LightScribe Support - OEM $79.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827136239
    Now , if you want to say that this could be an extreme Pc , then you have some high quality components to back it up. Maybe you could look through this setup and say you want it or you can make your own adjustments as to what you want or what you can afford. I am sure that other people who read this are going to weigh in with thier thoughts. Total as listed----$1808.92
    Ps --the SSD is for the OS.
  4. Best answer selected by kllrfrk.
  5. This topic has been closed by Mousemonkey
Graphics Cards Hardware Graphics
