Hi,
This is probably a stoopid question but I've confused the hell out myself.
Bought a DGND3300v2 router/modem to replace the standard Sky crappy router due to limited range and frequent disconnects.
My g/f and I both have Acer laptops and whilst they support 802n they don't appear to support the 5GHz band as I can only see the N network when I set it to 2.4GHz.
So it looks like the optimal setting is the N network at 300mbs on 2.4GHz (with G network off).
Is this the best setting to use if we cannot get 5GHz?
Also, I'm confused on speed. If we have 10MB broadband then does 145mbs or 300mbs make a difference? i.e. is the router or the broadband the bottleneck?
Apologies if this is a dumb question but my head hurts and google is driving me nuts trying to find an answer.
Cheers,
Alan
Cheers,
Alan
