Which power supply do I get?
Power Supplies
Components
- Product
Last response: in Components
UnsolvedCypher
March 10, 2012 9:24:51 PM
Hello,
I'm doing my first build of a computer, and have chosen these parts so far: https://docs.google.com/open?id=0B1cXHxu9p9o6U2J6QnVlQ3...
My problem is that I'm not sure what kind of power supply I need. Also, is the video card I chose appropriate for some Photoshopping but not much gaming? I don't intend to play games on my PC. Could you please give me some feedback on my parts (what needs rethinking). Also, I'm thinking of getting an Antec P280 for a case, but it's out of stock so I can't include it on my wishlist right now. Am I missing any parts?
Thanks, ~Unsolved Cypher
More about : power supply
For photoshop you are better of with a nvidia card GT520 would be enough a good quality around 400watt PSU would be enough. http://www.newegg.com/Product/Product.aspx?Item=N82E168...
m
l
UnsolvedCypher said:
Hello,I'm doing my first build of a computer, and have chosen these parts so far: https://docs.google.com/open?id=0B1cXHxu9p9o6U2J6QnVlQ3...
For a 6770 all you need is a good 400-450W PSU. The Corsair Builder series 430W would be sufficient. http://www.newegg.com/Product/Product.aspx?Item=N82E168... If you want to build in extra power for a more powerful video card then you could consider something like this OCZ....great deal with instant discount and $20 rebate. http://www.newegg.com/Product/Product.aspx?Item=N82E168... If you're not buying before the discount ends, then I would go with the Corsair.
The 6770 is a great price/performance card, but picture manipulation doesn't really rely on the video card...that really falls on the CPU. I would seriously reconsider the CPU...which means the mobo too. The Intel i5 2400 spanks the 8120 in just about every way and costs the same. http://www.newegg.com/Product/Product.aspx?Item=N82E168... A good mobo to go with the i5 2400 is: http://www.newegg.com/Product/Product.aspx?Item=N82E168... or http://www.newegg.com/Product/Product.aspx?Item=N82E168... If you go for one of these less expensive mobos, then you could even upgrade the CPU to an i5 2500K: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
I have an Antec P183 and love it...I think the P280 is an awesome case as well. Slightly less expensive case that's really worth considering for $99 is the Fractal Design Define R3: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The SSD is great, but lacks storage capacity for media (music, video, pics). If you have another HDD from an old PC, then I would use it as a temporary source of extra storage. HDD prices are still high after the flooding in Thailand last year. If/When the 1TB+ drives drop below $100, then I would consider increasing internal storage capacity.
m
l
- Which 970 and power supply - Forum
- Which Power Supply Do I Choose? - Forum
- Which power supply should I go with this build? - Forum
- which power supply? - Forum
- Which power supply should I get? - Forum
UnsolvedCypher
March 11, 2012 4:05:36 PM
rolli59 said:
For photoshop you are better of with a nvidia card GT520 would be enough a good quality around 400watt PSU would be enough. http://www.newegg.com/Product/Product.aspx?Item=N82E168...Thanks for the quick reply. Seems like a great card for Photoshopping and light gaming, so I'll add that. Thanks again!
m
l
UnsolvedCypher
March 11, 2012 4:10:58 PM
Rugger said:
For a 6770 all you need is a good 400-450W PSU. The Corsair Builder series 430W would be sufficient. http://www.newegg.com/Product/Product.aspx?Item=N82E168... If you want to build in extra power for a more powerful video card then you could consider something like this OCZ....great deal with instant discount and $20 rebate. http://www.newegg.com/Product/Product.aspx?Item=N82E168... If you're not buying before the discount ends, then I would go with the Corsair.The 6770 is a great price/performance card, but picture manipulation doesn't really rely on the video card...that really falls on the CPU. I would seriously reconsider the CPU...which means the mobo too. The Intel i5 2400 spanks the 8120 in just about every way and costs the same. http://www.newegg.com/Product/Product.aspx?Item=N82E168... A good mobo to go with the i5 2400 is: http://www.newegg.com/Product/Product.aspx?Item=N82E168... or http://www.newegg.com/Product/Product.aspx?Item=N82E168... If you go for one of these less expensive mobos, then you could even upgrade the CPU to an i5 2500K: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Wow. Thanks for all the details. I checked PassMark, and the 8120 seems to have a higher score. Where did you get the info about the 2400 being better? I'll look into the Define R3, it seems pretty nice. Also, I have a few HDDs I can stick in for extra storage. Thanks for all the info!
m
l
Best solution
550D
i3 2120
ASUS P8Z68 PRO
Vengeance 8GB
7750
430w
A List of Recommended PSUs
The Corsair 550D is far more superior than the P280. The i3 will beat out any AMD CPU, even the Phenoms and the 8150.
Why spend so much on memory when you could get a cheaper, one slot 8GB DIMM? The 7750 is dead silent and will play some of the medium games maxed out, and it beats the 6770. The Rosewill 430w will provide more amps and is much quieter than the CX430. There has been many complaints about the CX430 making a loud, annoying whine.
i3 2120
ASUS P8Z68 PRO
Vengeance 8GB
7750
430w
UnsolvedCypher
March 11, 2012 8:38:00 PM
e56imfg said:
550Di3 2120
ASUS P8Z68 PRO
Vengeance 8GB
7750
430w
Thanks for the feedback. How is the Corsair 550D superior to the P280? How is the Antec EarthWatts Green EA-430D for a power supply? Thanks to your and others' suggestions, I'm rethinking my system. The new wishlist can be found at . Thanks again for everyone contributing!
m
l
Thanks for the feedback. How is the Corsair 550D superior to the P280? How is the Antec EarthWatts Green EA-430D for a power supply? Thanks to your and others' suggestions, I'm rethinking my system. The new wishlist can be found at . Thanks again for everyone contributing!The Corsair 550D is better built and has better cable grommets than the P280.
Let's change a few things based on your list.
OCZ Vertex 3 120GB
Rosewill Green Series RG430-S12
ASRock Z68 PRO3 GEN3
8GB Vengeance
A List of Recommended SSDs
If you want to go with the P280, go for it. Cases are really just personal preference but I believe the 550D is better than the P280. You don't need to spend that much on a PSU that performs about the same.
m
l
UnsolvedCypher
March 15, 2012 5:07:53 PM
Sorry it's taken me so long to get back. I've looked at the SSD, but it seems to be having some serious problems. I'll go for the Mushkin Chronos SSD instead, as Newegg has a great price for it right now. The PSU you chose looks good, so I'll get that, but the motherboard seems to have quite a few minor issues. Would you recomend it over the ASUS P8Z68-V? As for the RAM, I think the Mushkin Enhanced Essentials 8GB looks good (I'm trying to buy everything from Newegg). But thanks for all the suggestions. An updated wishlist can be found here. Thanks again for your suggestions!
~Unsolved Cypher
~Unsolved Cypher
m
l
Sorry it's taken me so long to get back. I've looked at the SSD, but it seems to be having some serious problems. I'll go for the Mushkin Chronos SSD instead, as Newegg has a great price for it right now. The PSU you chose looks good, so I'll get that, but the motherboard seems to have quite a few minor issues. Would you recomend it over the ASUS P8Z68-V? As for the RAM, I think the Mushkin Enhanced Essentials 8GB looks good (I'm trying to buy everything from Newegg). But thanks for all the suggestions. An updated wishlist can be found here. Thanks again for your suggestions!~Unsolved Cypher
Which Z68-V are you talking about?
What do you not like about the ASRock mobo?
m
l
UnsolvedCypher
March 15, 2012 8:49:22 PM
e56imfg said:
Which Z68-V are you talking about? What do you not like about the ASRock mobo?
I'm talking about this, sorry it wasn't very clear. This is the motherboard I had before. If you look at the reviews of the ASRock motherboard, you see some minor issues. Sometimes the mouse isn't recognized by the motherboard, sometimes UEFI loads by itself, flimsy SATA, random dropping of USB 3.0 at times, and I'd just prefer to buy from a better known brand such as Asus. But again, this is my first build, and if you would recommend this board, I will get it. Other than that, how does my system look? Also, is it worth upgrading to an i5 2500 over the 2400?
m
l
Wow. Thanks for all the details. I checked PassMark, and the 8120 seems to have a higher score. Where did you get the info about the 2400 being better? I'll look into the Define R3, it seems pretty nice. Also, I have a few HDDs I can stick in for extra storage. Thanks for all the info!When not GPU limited, even the i3 2100 is comparable to an 8120 overclocked to 4.2 for gaming.
http://www.tomshardware.com/reviews/gaming-fx-pentium-a...
m
l
UnsolvedCypher
March 15, 2012 10:34:47 PM
Ok then, how does the build look? Anymore revisions?Thanks, ~Unsolved Cypher
I would switch out the memory for CORSAIR Vengeance 8GB (2 x 4GB) or G.SKILL Sniper Low Voltage Series 8GB because of the lower voltages- just be careful of future CPU heatsinks with the G Skill.
You could go cheaper and get G.SKILL Ripjaws Series 8GB
m
l
UnsolvedCypher
March 15, 2012 11:24:37 PM
e56imfg said:
I would switch out the memory for CORSAIR Vengeance 8GB (2 x 4GB) or G.SKILL Sniper Low Voltage Series 8GB because of the lower voltages- just be careful of future CPU heatsinks with the G Skill. You could go cheaper and get G.SKILL Ripjaws Series 8GB
Hmm, is it really worth it? This seems to suggest otherwise, but again, if you really think it's worth it, I'll get it. Is this all?
m
l
Hmm, is it really worth it? This seems to suggest otherwise, but again, if you really think it's worth it, I'll get it. Is this all?Thanks, ~Unsolved Cypher
Low voltages produces less heat which, according to Intel, makes the overall system cooler.
Not to mention the heat produced by the RAM could severely damage the motherboard and the CPU.
m
l
Be sure to check the default RAM voltages on your mobo. It may default to higher voltages than your RAM requires...adjust as necessary. It's true that low heat, and less power consumption produces less heat, but the idea that NOT running low voltage memory would possibly lead to overheating your motherboard is complete bunk.
m
l
UnsolvedCypher
March 16, 2012 2:21:28 PM
e56imfg said:
Low voltages produces less heat which, according to Intel, makes the overall system cooler. Not to mention the heat produced by the RAM could severely damage the motherboard and the CPU.
I can't seem to find any low voltage RAM that comes in 1 8gb stick. I really want to use only one slot, as this system will probably get many upgrades in the future.
m
l
Unless you're planning on doing a lot of overclocking, performance gains from uber RAM versus basic RAM from a reliable manufacturer will be minimal. If you're going to do a lot of overclocking the getting better quality RAM will allow you to OC higher. I think you'd be better off spending the extra money on a better GPU. Go for something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
no concerns about interference with your CPU cooler, either...
m
l
UnsolvedCypher
March 16, 2012 3:12:39 PM
Rugger said:
Unless you're planning on doing a lot of overclocking, performance gains from uber RAM versus basic RAM from a reliable manufacturer will be minimal. If you're going to do a lot of overclocking the getting better quality RAM will allow you to OC higher. I think you'd be better off spending the extra money on a better GPU. Go for something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E168...no concerns about interference with your CPU cooler, either...
Hmm, I'm defenitely not going to do a lot of gaming, and I've heard that Photoshop won't take much GPU. I think the integrated graphics should be fine. Or do you think I really do need the GPU? Other than that, how does my system look?
m
l
If you're not going to do a lot of gaming, then you can go with the integrated graphics. You can buy some extra capacity in the PSU in case you decide to get a GPU later. The Antec Earthwatt PSUs are on sale at Newegg and the EA-430 is $45: http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The EA-380D is actually more than enough and has spare capacity for a low-medioum GPU upgrade in your rig. http://www.newegg.com/Product/Product.aspx?Item=N82E168... It would just be hard for me to pay the same $45 for EA-380...
m
l
aqe040466
March 16, 2012 5:13:30 PM
For photoshop applications you can use the iGPU(Integrated Graphics Processing Unit) of the 2nd Gen Sandy Bridge CPU's e.g. i3, i5 or i7 They call it Intel HD 3000 which is embedded inside the CPU. I used to utilized this iGPU for a about 3 months fro gaming like A.V.A., Combat Arms, Need For Speed World and believe me it gives a high FPS (FRAPS) 100 FPS and above. So for photoshop application that will work. I can't really recommend which CPU would you use because I don't know your budget for this build.
As you can read in my signature below I'm using i5 2500K overclocked at 4.7 GHZ.
m
l
UnsolvedCypher
March 16, 2012 10:26:45 PM
Rugger said:
If you're not going to do a lot of gaming, then you can go with the integrated graphics. You can buy some extra capacity in the PSU in case you decide to get a GPU later. The Antec Earthwatt PSUs are on sale at Newegg and the EA-430 is $45: http://www.newegg.com/Product/Product.aspx?Item=N82E168... The EA-380D is actually more than enough and has spare capacity for a low-medioum GPU upgrade in your rig. http://www.newegg.com/Product/Product.aspx?Item=N82E168... It would just be hard for me to pay the same $45 for EA-380...
What about the PSU already on my wishlist? I was told that had very good performance. Or is Antec superior?
m
l
UnsolvedCypher
March 16, 2012 10:28:56 PM
aqe040466 said:
For photoshop applications you can use the iGPU(Integrated Graphics Processing Unit) of the 2nd Gen Sandy Bridge CPU's e.g. i3, i5 or i7 They call it Intel HD 3000 which is embedded inside the CPU. I used to utilized this iGPU for a about 3 months fro gaming like A.V.A., Combat Arms, Need For Speed World and believe me it gives a high FPS (FRAPS) 100 FPS and above. So for photoshop application that will work. I can't really recommend which CPU would you use because I don't know your budget for this build.As you can read in my signature below I'm using i5 2500K overclocked at 4.7 GHZ.
Thank you for that review, now I can feel confident about the integrated graphics
m
l
Rugger said:
Be sure to check the default RAM voltages on your mobo. It may default to higher voltages than your RAM requires...adjust as necessary. It's true that low heat, and less power consumption produces less heat, but the idea that NOT running low voltage memory would possibly lead to overheating your motherboard is complete bunk.UnsolvedCypher said:
m
l
UnsolvedCypher
March 16, 2012 11:23:14 PM
e56imfg said:
I never said 1.5v would overheat but 1.6v+ will. The Antec is using an outdated PSU method. The Rosewill will also give you one more amp oppose to the 32 Amps Antec gives- not much but at least it's using an up to date method.
So about the RAM, you said that the low power will make the system cooler. But if I'm using 2x4gb, that means that I have two 1.25v (or whatever the voltage is) sticks. If I buy 1 8gb regular power stick, then I still only have one 1.5v, which is less than 2x1.25. So does the lower voltage RAM actually make my system cooler over the 1 stick? And thanks for the PSU tip, I'll stick with Rosewill.
m
l
m
l
aqe040466
March 17, 2012 11:32:09 AM
So about the RAM, you said that the low power will make the system cooler. But if I'm using 2x4gb, that means that I have two 1.25v (or whatever the voltage is) sticks. If I buy 1 8gb regular power stick, then I still only have one 1.5v, which is less than 2x1.25. So does the lower voltage RAM actually make my system cooler over the 1 stick? And thanks for the PSU tip, I'll stick with Rosewill.The voltage doesn't really matters. In the BIOS you can always choose the "XMP"profile for the RAM which automatically switch to default RAM voltage.
m
l
aqe040466
March 17, 2012 11:35:02 AM
So you're saying that using 1.6V RAM will overheat and in your words: "could severely damage the motherboard and the CPU"?
What is the outdated PSU method that Antec is using in its Earthwatts PSUs? What makes the Rosewill Green series you suggested superior to an Antec Earthwatts? Please provide specifics or links.
m
l
aqe040466 said:
OCZ, Antec, Corsair and Silver Stone these are trusted brands of Great PSU's.There are more trustworthy brands than this...Seasonic, FSP, XFX to name a few. The Rosewill Capstone's are excellent PSUs made by a quality OEM, Superflower. Generalizations are useful, but only to a certain point....
m
l
Rugger said:
So you're saying that using 1.6V RAM will overheat and in your words: "could severely damage the motherboard and the CPU"? What is the outdated PSU method that Antec is using in its Earthwatts PSUs? What makes the Rosewill Green series you suggested superior to an Antec Earthwatts? Please provide specifics or links.
I'm not saying 1.6+ could severely damage the motherboard but it voids Intel's warranty and it's more likely to happen with 1.6+ than any other low voltage.
And why are you trying to start a flame war?
m
l
UnsolvedCypher
March 17, 2012 6:49:11 PM
Can we please stay away from the low voltage RAM argument? I'm going to go with the 1 Mushkin 8gb stick. Does anyone else have any thoughts as to what looks good and what needs to be rethought?Thanks guys!
G.SKILL Ripjaws X Series 8GB
Mushkin Enhanced Blackline 8GB
Mushkin Enhanced Blackline 8GB Low Voltage
RAM just works like it's suppose to so it's really a matter of personal preference.
m
l
e56imfg said:
The Outdated DesignI'm not saying 1.6+ could severely damage the motherboard but it voids Intel's warranty and it's more likely to happen with 1.6+ than any other low voltage.
I'm not trying to start a flame war. It's just that your post read like you were saying that non-low voltage RAM would damage his motherboard...I didn't want the OP to get misled about RAM.
The Rosewill must have the same outdated design as the Antec...they both have most of the power on the 12V rails. The Rosewill does have 396W while the Antec has only 384W, but that doesn't mean the Antec is an outdated design.
Cypher: If you don't plan on OCing, then the least expensive, compatible RAM from a good manufacturer will work well for you and save some money. I personally prefer the Corsair Value Select: http://www.newegg.com/Product/Product.aspx?Item=N82E168... but I've also like Mushkin http://www.newegg.com/Product/Product.aspx?Item=N82E168... and Patriot http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The 2x4GB sets that e56 linked are good sets, too, and they are less expensive than than buying single 8GB sticks.
IRT the PSU, I didn't see one in your wish list link above. What PSU was it? BTW both the Rosewill Green that e56 linked and the Antec Earthwatts that I linked are good quality PSUs with sufficient power for your rig and headroom in case you want to add a low to moderate GPU later.
m
l
UnsolvedCypher
March 18, 2012 8:53:52 PM
e56imfg said:
Sorry. The RAM is fine but you could get faster ones at a lower price.G.SKILL Ripjaws X Series 8GB
I've read that the difference between 1333 and 1600 is almost unnoticable, so I don't know if it's worth it. I'm also looking for 1 8gb stick, so that I can upgrade in the future. But thanks for the tips!
m
l
m
l
UnsolvedCypher
March 18, 2012 8:59:41 PM
The one in my wishlist was the Rosewill, and since you both recommend it I'll keep it. I like it a bit better than the Antec just because of the Antec's green color, since that seems to be the only difference. As for the RAM, I just changed my mind (sorry, I'm contradicting my previous post). I'll get a 2x4, the low power one that e56 suggested.
m
l
UnsolvedCypher
March 18, 2012 9:01:15 PM
e56imfg said:
G.SKILL Ripjaws X Series 16GB would be a nice choice, although a bit pricey.Thanks, but for now I'll just be buying 8gb, which should be sufficient. When I need an upgrade, I'll go for more RAM, but for now I'm good. Thanks again!
m
l
UnsolvedCypher
March 18, 2012 9:27:49 PM
UnsolvedCypher
March 18, 2012 9:31:40 PM
e56imfg said:
Everything is good to go. Give us a the final list before you go and buy, just in case.OK, here is the final list. Thanks so much for all your help, guys.
m
l
UnsolvedCypher
March 18, 2012 9:32:14 PM
m
l
UnsolvedCypher
March 19, 2012 9:56:34 PM
- SolvedCan someone suggest an alternative power supply for this build which is of similar price and quality? Forum
- SolvedWhich power supply should i use for 750 ti Forum
- SolvedPower supply has to go. No, I am not asking which one to buy. Forum
- SolvedWhich Power Supply? Forum
- SolvedIs My Core 2 Duo E7400 2.80 GHz ..... Compatible With radeon hd 7770 GPU ...? And if it is Which power supply should i have t Forum
- SolvedWhich power supply is better? Forum
- SolvedTwo choices on power supply, which is better. Corsair CX-750 V3 or Aerocool GT700S 700W. Forum
- Solvedwhich power supply to use? Forum
- SolvedWhich Power Supply is best for me Forum
- SolvedWhich Power Supply Should I Use Forum
- SolvedCant decide which motherboard, and what power supply will I need? Forum
- Solvedfx 8350 and msi r9 280x in a prodigy or prodigy m case, which motherboard, power supply, ram etc? Forum
- SolvedWhich Power supply should I get? Forum
- SolvedWhich power supply should I get for 650-700 watts Forum
- More resources
Read discussions in other Components categories
