Hi all, recently I have just built a new computer. It's the first one I've built so it's relatively low-end and I'll list the specs below. After putting it all together it was running fine, then today I went to update windows 7 64-bit and it asked me to restart the computer to install the updates so I did and when it rebooted there was no display. It was working fine for the first couple of days that I have had it. I have went through troubleshooting and steps on this site for first time builds and everything checks out. When I plug it in and turn it on it gives a short beep as if it is posting but no display. I can even hear windows loading if I plug in the speaker.
I have taken the gpu out and put it back in, I have reset CMOS, I have unplugged/replugged all the cables. The fans work and everything else seems to be fine.
computer specs:
biostar n68s3+
amd athlon ii x3 rana
4gig ddr3 (one stick)
ecs gt 440 1gig ddr5
seagate 500 barracuda
lg 48x dvd/cd combo
rosewill r103a case w/350 watt psu
windows 7 64
I have HDMI display running from the gpu to a viore 22 in. lcd monitor. This is the only desktop pc I have and no other spare parts to try out lying around.
computer specs:
biostar n68s3+
lg 48x dvd/cd combo
windows 7 64
