Hello,
My newish build as of Nov. 20th started having issues on Sunday posting.
On Sunday I powered on the system and it powered on however the monitor never gave display. No beeps. I powered down the system and powered it back on and it then posted fine. When I powered it down it powered down upon touch...(didn't have to hold it down for 4 seconds.) Once I game up I gamed normally for a couple of hours.
Yesterday I experienced the same issue only I had to power it off and on several times before it made it to post.
Today, same issue but I only had to power it off and on once. The last day I didn't have issues was on Saturday. The only notable thing I did was I had a rather intense gaming session that day. I probably played for 4 or 5 hours including a long session of BF3. Thinking maybe the heat caused some type of issues. During that time my core temps got to about 50C and my video card ran in the mid 60s and peaked at 70C. Here is HW Monitor output under normal load.
CPUID HWMonitor Report
Binaries
HWMonitor version 1.1.8.0
Monitoring
Mainboard Model P67A-G43 (MS-7673) (0x000003EE - 0x52735B20)
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71889A
LPCIO Vendor ID 0x1934
LPCIO Chip ID 0x1005
Config Mode I/O address 0x4E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 04 FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 10 05 31 19 34 00 00 92 20 01 C0 30 10 08 00 00
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor Fintek F71889A
Voltage 0 3.30 Volts [0xCE] (+3.3V)
Voltage 1 0.95 Volts [0x77] (CPU VCORE)
Voltage 2 1.84 Volts [0x73] (VIN2)
Voltage 3 1.41 Volts [0x78] (VIN3)
Voltage 4 5.72 Volts [0x88] (+5V)
Voltage 5 8.10 Volts [0x5C] (+12V)
Voltage 6 2.06 Volts [0x81] (VIN6)
Voltage 7 3.22 Volts [0xC9] (VSB3V)
Voltage 8 3.34 Volts [0xD1] (VBAT)
Temperature 0 35°C (95°F) [0x23] (TMPIN0)
Temperature 1 42°C (107°F) [0x2A] (TMPIN1)
Temperature 2 29°C (84°F) [0x1D] (TMPIN2)
Fan 0 2104 RPM [0x2C9] (FANIN0)
Fan PWM 0 100 pc [0xFF] (CPU)
Fan PWM 1 100 pc [0xFF] (System Fan 1)
Fan PWM 2 100 pc [0xFF] (System Fan 2)
00 FF C3 00 01 01 FF FF 00 00 00 02 00 62 4C 00 30
10 00 00 00 00 00 00 06 FF FF FF FF FF FF FF FF FF
20 CE 77 73 78 88 5C 81 C9 D1 FF FF FF FF FF FF FF
30 7A D7 FF FF FF FF C9 C8 75 85 FF FF FF FF FF 00
40 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 FF FF FF FF FF FF FF FF FF FF 03 04 10 19 34 FF
60 00 00 EE 00 FF FF 00 00 00 00 FF 08 40 24 FF 00
70 FF FF 23 FF 2A FF 1D FF 23 00 23 23 23 00 00 00
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF A8 FF
90 00 06 06 00 16 FF 3F FF 44 04 00 2A 55 05 99 0A
A0 02 C9 00 FF 03 6B 3C 32 28 1E FF E5 CE B7 A0 0D
B0 0F FF 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
C0 0F FF 00 FF 03 FF 3C 32 28 1E FF D9 B2 99 80 0F
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 01 00
F0 00 00 00 00 00 00 33 FF 02 BA FF 00 FF 00 FF FF
Hardware monitor AMD ADL
Voltage 0 0.95 Volts [0x3B6] (VIN0)
Temperature 0 38°C (100°F) [0x26] (TMPIN0)
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 8)
Number of threads 4 (max 16)
Name Intel Core i5 2500K
Codename Sandy Bridge
Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Package (platform ID) Socket 1155 LGA (0x1)
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
Core Speed 1596.4 MHz
Multiplier x FSB 16.0 x 99.8 MHz
Stock frequency 3300 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 33x
Max turbo ratio 37x
Max efficiency ratio 16x
Min Power 60 Watts
O/C bins unlimited
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01400005h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000206A7 0x00100800 0x1F9AE3BF 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B0FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00001FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300803 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x49202020 0x6C65746E 0x20295228
0x80000003 0x65726F43 0x294D5428 0x2D356920 0x30303532
0x80000004 0x5043204B 0x20402055 0x30332E33 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000001
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00001000 0x70012100
MSR 0x00000017 0x00040000 0x00000000
MSR 0x00000035 0x00000000 0x00040004
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x22232425
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x883F0000
MSR 0x000001FC 0x00000000 0x0004005D
MSR 0x00000601 0x18141494 0x8000038C
MSR 0x00000602 0x18141494 0x8000011C
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000610 0x000083B6 0x001482F8
MSR 0x00000611 0x00000000 0x527CC5A0
MSR 0x00000639 0x00000000 0x36D84EF0
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000614 0x00000000 0x01E002F8
MSR 0x0000019C 0x00000000 0x883F0000
MSR 0x000001A2 0x00000000 0x00621200
MSR 0x00000198 0x00002006 0x00001000
MSR 0x00000199 0x00000000 0x00001000
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01400005h
CPUID
0x00000001 0x000206A7 0x02100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x00000611 0x00000000 0x527D3986
MSR 0x00000639 0x00000000 0x36D88767
MSR 0x0000019C 0x00000000 0x88430000
MSR 0x00000198 0x00001F62 0x00001000
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01400005h
CPUID
0x00000001 0x000206A7 0x04100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x527DACDB
MSR 0x00000639 0x00000000 0x36D8BF55
MSR 0x0000019C 0x00000000 0x88420000
CPU Thread 3
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01400005h
CPUID
0x00000001 0x000206A7 0x06100800 0x1F9AE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000006
MSR 0x00000611 0x00000000 0x527E2909
MSR 0x00000639 0x00000000 0x36D8FF42
MSR 0x00000198 0x00001F10 0x00001000
Storage
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x0024
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x0B0E, product=0x090A
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x0461, product=0x4D22
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name Radeon HD 6870
Codename Barts
Technology 40 nm
Memory type GDDR5
GPU ref clock 27000
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x174B)
Model ID 0x6738 (0x174B)
Binaries
Monitoring
LPCIO
LPCIO Vendor Fintek
LPCIO Model F71889A
Config Mode LDN 0x4
Hardware Monitors
Processors
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 2
-- Core 2
-- Thread 0 4
-- Core 3
-- Thread 0 6
Processor 1 ID = 0
CPUID 6.A.7
Extended CPUID 6.2A
Core Stepping D2
Technology 32 nm
TDP Limit 95 Watts
FID/VID Control yes
Max turbo ratio 37x
Min Power 60 Watts
O/C bins unlimited
Thread dumps
CPU Thread 0
APIC ID 0
Type 01400005h
CPUID
CPU Thread 1
APIC ID 2
Type 01400005h
CPUID
CPU Thread 2
APIC ID 4
Type 01400005h
CPUID
CPU Thread 3
APIC ID 6
Type 01400005h
CPUID
Storage
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name Radeon HD 6870
Codename Barts
Technology 40 nm
Memory type GDDR5
GPU ref clock 27000
