Nothing showing on monitor after installing power supply
I installedlnew power supply and now my monitor says no signal. What can I do?
3 answers Last reply
More about nothing showing monitor installing power supply
  1. Check your cables. Make sure you have the 20/24 pin AND the 4/8 pin CPU power and that all your drives are powered. Remove and reseat them all to be sure. A minimum of 4 wires coming off the PSU should be plugged in, 20/24 pin, 4/8 pin, HDD and Optical drive.
  2. What system specs? Maybe discrete GPU that needs power from PSU?
  3. Check the seating of the graphics card by removing and refitting it as it is common to dislodge it when changing the power supply also try the same with the memory. Another common mistake is to forget to fit the 4 pin connector. If this does not work can you try the old power supply again?
Power Supplies Monitors Components
