Hey y'all,
I recently purchased parts for a new gaming rig and can't get it to boot. As in, nothing happens on the display whatsoever.
I am using a ASUS P8P67 PRO mobo and Patriot G2 series RAM (2x4GB). Here are links to both:
Mobo and RAM
When I press the power button the CPU LED blinks once and turns off (that is working correctly). The MEMOk! light, however, stays red which would indicate a RAM issue. However, I'm not good enough to know why that doesn't work exactly. I have tried reseating the RAM in each slot (only one stick at a time to minimize problems) and it still does the same thing. After that I tried holding down the MEMOk! button to boot from that so it would run a series of tests to diagnose the problem and boot correctly. Note that all the proper fans/lights on the case are working.
Is this a RAM issue, and if so, what should I buy instead of what I currently own? Thanks guys!
The rest of my parts:
CPU: Intel Core i5 (click the mobo link above to view the specs on that)
Video: GeForce 550Ti
PSU: Thermaltake 430W XP550NP
Mobo and RAM
