Just wondering if this ram will work on my M4N98TD Evo motherboard. The ram is Corsair Vengeance 8gb (2x4gb) 1600mhz ram ID number is CMZ8GX3M2A1600C9.
Okay I got it to work but only one stick is showing up. Seems to only be running in single channel. I've been having this problem for a few days now. Any ideas?
You can try to add the RAM one at a time to the slot that closed to the CPU, if it don't work then is bad, you need to RMA if you just bought, or you need other RAM.
Well I've tested this ram and it works. as well as the slots. Plus my old ram just started doing the same thing. Only running in single channel and I don't know why.
