Hi
Im going to build a new desktop and i want to know if i have anything thats not compatible
Case: COOLER MASTER HAF 932 Advanced Blue Edition (http://www.newegg.com/Product/Product.aspx?Item=N82E16811119213)
HDD : SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
(http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185)
VGD(sli) : EVGA 012-P3-1571-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI (http://www.newegg.com/Product/Product.aspx?Item=N82E16814130613)
Power : XION XON-1000P14F High Performance 1000W Power Supply, compatible with Intel Sandybridge Core i3/i5 /i7 (http://www.newegg.com/Product/Product.aspx?Item=N82E16817190030)
Ram : CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model (http://www.newegg.com/Product/Product.aspx?Item=N82E16820233143)
Motherboard : ASUS P8P67 PRO (REV 3.1) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
(http://www.newegg.com/Product/Product.aspx?Item=N82E16813131771)
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor (http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070)
CPU fan: ZALMAN CNPS9900MAX-B 135mm Long life bearing CPU Cooler Blue LED
