ojhasha Distinguished Jan 8, 2012 61 0 18,630 Mar 12, 2012 #1 http://www.newegg.com/Product/Product.aspx?Item=N82E16812119148
Solution scout_03 Mar 12, 2012 this is the one you neeed the other is reverse connector http://www.newegg.com/Product/Product.aspx?Item=N82E16812200855
scout_03 Titan Ambassador Feb 18, 2010 30,566 321 107,640 Mar 12, 2012 Solution #3 this is the one you neeed the other is reverse connector http://www.newegg.com/Product/Product.aspx?Item=N82E16812200855 Upvote 0 Downvote Solution
rolli59 Titan Oct 27, 2007 47,790 283 130,890 Mar 12, 2012 #4 scout_03 : this is the one you neeed the other is reverse connector http://www.newegg.com/Product/Product.aspx?Item=N82E16812200855 Yep you are correct the other one has 2 x female! Upvote 0 Downvote
scout_03 Titan Ambassador Feb 18, 2010 30,566 321 107,640 Mar 12, 2012 #5 thanks rolli59 Upvote 0 Downvote
ojhasha Distinguished Jan 8, 2012 61 0 18,630 Mar 12, 2012 #6 Best answer selected by ojhasha. Upvote 0 Downvote
