Will Water cooling fit?
Hello! I have a Antec H2o 620 water cooling unit in my system right now. I want to get the LIAN LI PC-V354B http://www.newegg.com/Product/Product.aspx?Item=N82E16811112300 Computer case but i'm wondering if i will have to scrap my cooler. I'm thinking of getting this case and a microatx motherboard with small heatsinks so it wont be in the way. if you have this case with any watercooling can you let me know? Thanks.
2 answers Last reply
More about will water cooling
  1. I doubt anyone has squeezed a W'c into a small case like that, but I wouldn't say its impossible
    you could mount it underneath that mesh on the top, although I would mount the rad inside and the fan may have to go outside on top, pulling the air out.
    depends on clearance once Mobo's in ofc, you may be alright as is
    Moto
  2. Never seen this case, but looking at add, top fan is 140mm exhaust. If front fans are intake, mount radiator on rear grill provided and fan external on back of case. That is above PSU and out of way of MB. Should work. Might be able to use push pull fans on radiator.
Antec Water Cooling Cases Components Product
