Sign-in / Sign-up
Dual monitor tearing with radeon 6850
  • Graphics Cards
  • HDTV
  • LCD
  • Dual Monitors
  • Graphics
Last response: in Graphics Cards
October 11, 2011 4:59:54 PM
Good Morning for the past few months I have been struggling with this.
My set:
a samsung LCD 20 monitor connected with DVI, and a Samsung HDTV 720p/ 1080i.
I was able to drive these both with my old 5570 radeon. with no problems.The LCD would run as 1920x1080 and the HDTV would run the same image but as 1080i
I can not get this to work with the 6850. If I set the LCD as the preffered monitor, the HDTV has a consistant tear about a 3rd of the way down. If I set the HDTV as preffered the LCD has a severe stuttering problem.
I would love any help that anyone has to give.
More about : dual monitor tearing radeon 6850
a c 290 U Graphics card
October 11, 2011 6:08:42 PM
What make/model of power supply are you using? Your 5570 did not require an additional power connection, but your 6850 does. It may simply be a matter of power. Please clarify.
m
l
October 18, 2011 6:01:18 PM
I have a 500w power cooler master supply. my CPU is a AMD Phenom x4 965 BE.
m
l
October 19, 2011 3:39:09 AM
Are you overclocking anything? If so, revert to stock speeds for all (CPU, GPU, and memory). If not, how are your temps? I suspect your PSU is the problem otherwise.
m
l
