Solved
Antec Earthwatts Power SUpply
  • Power Supplies
  • Antec
  • SLI
  • Components
Last response: in Components
March 12, 2012 11:07:09 AM
Is Antec Earthwatts Power SUpply worth buying ? its cheaper than corsair TXV2 750.
i have a phenom ii x4960t and SLI gtx 550ti SLI ,
i need a good power supply which can fulfill it . Queestion is Will Antec Earthwatts Power SUpply Will do ?
Is it good psu ?
and other question , is this Eggxpert Tiered Power Supply List good ? - http://www.eggxpert.com/forums/thread/323050.aspx
it says Antec Earthwatts is good .
More about : antec earthwatts power supply
Best solution
March 12, 2012 11:20:42 AM
with all power supplies you have a <%5 chance of getting a dud. but overall antec makes great power supplies and their earthwatts is just one of their high efficiency product lines.
a b ) Power supply
March 12, 2012 12:33:51 PM
Stick with the Antec, they have a good reputation while the Eggxprt sounds like a cheapo chinese mass produced firecracker.
m
l
March 12, 2012 1:28:00 PM
a earthwatts psu is a good and well known psu with reputation and its good for your built.:)
m
l
March 12, 2012 1:57:36 PM
I've got Antec Earthwatts PSUs over 4 years old still running fine, they're very quiet too.
m
l
March 12, 2012 5:02:00 PM
thats not a power supply name its a sister site of newegg.com it provides advise on buying.
m
l
March 12, 2012 5:44:06 PM
dude can i ask u one question ? where are u from ? i mean which country ?
i wrote the quest. in a hurry and if u read it carefully its written - eggxpert tiered power supply "list".
i didnt say that its a name of psu
m
l
March 13, 2012 11:49:38 AM
umm.... sorry but i didnt quote you. so that comment wasnt for you. it was for das_stig.
edit: and im in colorado. and i read your question and understood it.
m
l
March 21, 2012 7:42:12 AM
Best answer selected by pratmodi.
m
l
