Hi, i've recently bought a coolermaster v8 for my home build. there had been no problems prior to installing it. i had to remove the motherboard to put the cooler on as its a weird design. i'm sure i had put everything back together correctly, but when i put the computer on and ran everests "strain test" (takes cpu to 100%) to look at the cpus temperatures the screen went green and then a few other colours before crasshing on a light blue colour.
i restet the pc and logged back in then left it to go get some food, came back and it had done the same this time stuck on a brown colour (everest wasn't running). since then i've had the computer on nearly an hour (20 minutes idle, 20 minutes a quick game of MW3 and the rest looking for a solution), nothing unusual has happened at all.
also i keep hearing a sort of slight popping noise as if air popping, could it be i have air bubbles in the thermal paste and they are escaping. i'm currently reading 36c on speedfan. i would have thought airbubbles would have made it higher.
and finally, i switched auto fan control off my gigabyte bios and have the CPU fan at around 1800RPM. is it better to have the bios control my fan speed or not.
thanks guys
thanks guys
