Ranew build ram help
Last response: in Systems
CASE : Rosewill THOR V2 Gaming ATX Full Tower – 99.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
PSU : CORSAIR Professional Series HX1050 – 209.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
Motherboard : ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard – 339.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
CPU : i7-3930k – 599.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
Cooler : CORSAIR H100 (CWCH100) Extreme Performance Liquid CPU Cooler – 119.99 http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
RAM : G.SKILL Ripjaws Z Series 16GB (4 x 4GB) – 84.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
SSD : Crucial M4 2.5" 128GB SATA III MLC Internal SSD – 214.99 http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
HDD : 2x Seagate Barracuda ST1000DM003 1TB 7200 RPM – 149.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... . (getting later )
GPU : GIGABYTE GV-N580UD-15I GeForce GTX 580 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card – 509.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
Optical : SAMSUNG CD/DVD Burner – 15.99 http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
OS : Microsoft Windows 7 Professional SP1 64-bit – OEM – 129.99 - http://www.newegg.com/Product/Product.aspx?Item=N82E168... .
is what im planing on building. i wanna know which of the 2 rams is better or best for my set up. if i can get sum pros or cons for both memory would be nice? or are they both the same??
http://www.newegg.com/Product/Product.aspx?Item=N82E168... CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML16GX3M4A1600C9
VS
More about : ranew build ram
I would get the Corsair ram. I have had nothing but trouble with my 24G GSkill kit. Not meeting the required speeds and 2 chips of the 6 failing in 9 months. everything else looks about equal for the timings. The Corsair also looks to be a lower profile and that equals less to worry about for a heat sink on the CPU.
Take your pick.
I have had no problems with G.skil or Corsair.
I have had one occasion to ask G.skil support a question about their ram, and they responded quickly and accurately.
With your liquid cooler kit the height of heat spreaders are irrelevant. Heat spreaders for 1.5v ram are largely marketing anyway.
Ask the community
