I need some advice on building my first HTPC/DVR. I primarily want it to record/watch over-the-air HD programming (ATSC), streaming online TV (e.g. Netflix), DVDs, and possibly Blu-ray. My HDTV accepts HDMI or D Sub. I am not much of a Linux person, so as of now I am planning to go with Windows 7 Media Center.
All suggestions are welcome.
CPU: I have read a lot of good reviews with AMD Llano (better graphics and lower cost than Intel route). Is an A4 adequate, or is an A8 overkill, dual/triple/quad core?
AMD A4-3400 Llano 2.7GHz Socket FM1 65W Dual-Core Desktop APU with DirectX 11 Graphic AMD Radeon HD 6410D - $70
AMD A6-3500 Llano 2.1GHz (2.4GHz Max Turbo) Socket FM1 65W Triple-Core Desktop APU with DirectX 11 Graphic AMD Radeon HD 6530D - $90
AMD A6-3650 Llano 2.6GHz Socket FM1 100W Quad-Core Desktop APU with DirectX 11 Graphic AMD Radeon HD 6530D - $120
AMD A8-3850 Llano 2.9GHz Socket FM1 100W Quad-Core Desktop APU with DirectX 11 Graphic AMD Radeon HD 6550D – $140
Motherboard: I am leaning towards one of the Gigabyte boards below based on price, features (2 PCI Express ports) and reviews.
ASRock A75M FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard with UEFI BIOS - $80 ($75 + $5)
GIGABYTE GA-A75M-D2H FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard - $80 (after mail in rebate)
GIGABYTE GA-A75M-UD2H FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard - $85 (after mail in rebate)
ASUS F1A75-M FM1 AMD A75 (Hudson D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard with UEFI BIOS - $100
Tuner Card: I already purchased a Hauppauge 2250.
Power Supply:
Antec EarthWatts Green EA-380D Green 380W Continuous power ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply - $47 ($45 + $2)
Antec EarthWatts Green EA-430D Green 430W Continuous power ATX12V v2.3 / EPS 12V 80 PLUS BRONZE Certified Active PFC Power Supply - $40 after rebate
Antec NEO ECO 400C 400W Continuous Power ATX12V 2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply - $25 after rebate
RAM: 4 GB should do be adequate? Any DDR3 SDRAM 1333?
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBPK - $25
Case: (cabinet depth is only about 17”, so I need a short case)
SILVERSTONE Black 8.0mm aluminum front panel, 0.8mm SECC body GRANDIA GD04B Micro ATX Media Center / HTPC Case $94 ($74 + $20)
SILVERSTONE Black Aluminum / 0.8mm SECC Grandia Series GD05B micro-ATX / Mini-DTX / Mini-ITX MB, 1x5.25", 2x3.5"+1x2.5"HDD or 1x3.5"+2x2.5"HDD, 3x120mm golf bladed fan, 11" expansion card capable HTPC Case $104 ($84 + $20)
Hard drive: a hard drive is a hard drive?
Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - $140
Blu-Ray Burner:
ASUS Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA Blu-ray Burner BW-12B1ST/BLK/G/AS – $85 ($100 - $20 + $5)
LITE-ON Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM SATA 12X Blu-ray Burner with Blu Ray 3D Feature IHBS112-04 – OEM - $85 ($100 - $20 + $5)
Free Cyberlink BD software w/ purchase, limited offer
