No connector for power/reset switch cables.
Related ressources
- Where can I get power/reset switches and wires? - Forum
- wires, cables and plugs oh my! need a 'lil help w/ wires - Forum
- Hooking up the power and reset switch ??? - Forum
- Switching Towers issue?? - Forum
- Powering MOBO problem [VIDEO] - Forum
Related ressources:
- ForumNew build. No power at all.
- ForumProblems After Switching To A New Case
- ForumHomebuilt Pc stopped turning on overnight. Help please?
- ForumSudden shutdown, will not boot afterwards
- ForumNewbie is in a mess...
- ForumDid I broke something?
- ForumThe most annoying computer problem ever
- ForumPSU 20+4 pin connector does not fit snuggly with Mobo
- ForumPower off button doesnt shut down PC ... restart after 1-2 secs
- ForumComputer turns off then on, No screen after upgrade to new cpu cooler
- ForumHelp! New mobo and can't connect the System Panel Connector
- Forum"Reboot and select Proper boot device"
- ForumI removed a pci card while power was on, now i can't power up
- ForumHow to connect power on cable on motherboard
- Forum24 Pin Connector won't go in all the way?
- More resources
Read discussions in other Motherboards categories
