Need Diagnostic tool
Looking for a Motherboard diagnostic tool/software for GIGABYTE 790A-UD3
Trying to see if the MOBO is failing with the RAM
3 answers Last reply
More about need diagnostic tool
  1. If only... diagnosing mobo problems can be very tough. Have you tried memtest? This will at tell you if the RAM is still working properly.
    http://www.memtest.org/
  2. Yeah, No errors came up
  3. Probably not RAM then. What error symptoms are you seeing otherwise?
Motherboards Gigabyte Software
