Tom's Hardware > Forum > Windows XP > Configuration & Customize > Right-click after opening Start Menu (SP2)
Forum Windows XP : Configuration & Customize - Right-click after opening Start Menu (SP2)
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hello All:
Here's the sequence that doesn't work after installing SP2:-
1) Left-click on Start button - works OK.
2) Right-click on any menu choice on Start Menu - doesn't work.
3) Left-click on any menu choice on Start Menu - works ok.
4) Right-click on any program in All Programs - doesn't work.
I've checked my context menu in the registry for non-MS shell
extensions. Disabled a couple - still doesn't work.
The funny thing is, I've two computers (one PC and one Laptop) with
almost identical configurations. The Laptop works everywhere but the PC
doesn't work as above.
I'd be really grateful for some help and solution to this.
Kind regards,
Russel
Sponsored Links
Have you enabled Drag n Drop in Start's Properties
'Not happy John! Defending our democracy',
http://www.smh.com.au/articles/200 [...] 35123.html
"Nospam Please" <nospam@all.please> wrote in message news:O62e9MbiEHA.3608@TK2MSFTNGP09.phx.gbl...
> Hello All:
> Kind regards,
> Russel
Reply to Anonymous
This is a common symptom of having Divx or some other programs installed. A
spyware removal program, I forget the name (spysweeper maybe), also does
this. Have a look at what you have installed to see what differs between
these 2 machines.
"Nospam Please" wrote:
> Hello All:
> Kind regards,
> Russel
Reply to giga
I have the same setup on both machines ... no Divx but the same spy
removers ... Ad Aware, Spybot Search & Destroy, and Spyware Blaster. On
the PC, though, I _did_ have a program known as DirPrn, which I removed.
But it hasn't helped. I hope somebody can help me find a cure for this
irritant, because, other than this, SP2 rocks!
Thanks again.
Russel
> these 2 machines.
>>Hello All:
>>Kind regards,
>>Russel
Reply to Anonymous
Brilliant! I enabled it and the dashed thing worked!
Many thanks, David.
Regards,
Russel
Reply to Anonymous
There are 945 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
