Hello,
I have been reading many of the helpful replies concerning the Pegatron M2N78-LA board. I have one that has (notoriously) failed in my HP p6310y.
I have looked up some of the suggestions for better replacements, but my question is, will they fit the hole pattern for the mounting screws?? And, will the rear ports fit the case opening for them?? I guess I need help with:
1) finding a better board that,...
2)fits the case screw holes and port openings, and..
3) is preferably under 100.00 dollars
Any help?? Thanks so very much!
