So I just finished my first build, the first time I put it together nothing happened so I tinkered with it for about 1.5 hours then I just took it completely apart and put it back together that seemed to fix it, all the fans spin and the drives work but nothing popped up on the screen and there were no beeps so I took out 1 of my sticks of RAM and it beeped once but nothing popped up on the screen it is still blank. Does anyone know what the problem is I already re-seated the CPU just to make sure. Also should I send back the RAM since one stick seems to be defective? Thanks.
