I just received components for a new system, and the 8-pin CPU power cable that came with the power supply is too short to route behind the motherboard tray and reach the MoBo connector. The power supply is an OCZ ZX 1250W (modular). It came with two of these cables, but they are both the same length (24in.). I'm building it in a Cooler Master Storm Trooper case. I routed it underneath the motherboard to get it out of the way. Two questions:
1. Does anyone know where I can by a replacement cable that is a bit longer? I think 2 or 3 more inches would do the trick.
2 It was a pretty tight fit underneath my MoBo. It isn't bulging it or bowing over it, but it is pretty tight. Will this be harmful to my motherboard to leave it this way?
Thanks for the help
Thanks for the help
