Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Urgent Build Help.
Urgent Build Help.
Forum Systems : New Build Urgent Build Help.
Page:    Previous 1 2 3 Next Bottom Search this thread
Okay...bottom line:
I was going to get this after a discussion with a very helpful person.
1.) http://www.tigerdirect.com/applica [...] =T925-8010
2.) http://www.tigerdirect.com/applica [...] u=B69-0483
3.) http://www.tigerdirect.com/applica [...] =P450-6792
After another discussion with some more very helpful people they said that build was rubbish. (bad components) And one suggested:
1.) http://www.newegg.com/Product/Prod [...] 6811129066
2.) http://www.newegg.com/Product/Prod [...] 6814102871
3.) http://www.newegg.com/Product/Prod [...] 6817341016
4.) http://www.newegg.com/Product/Prod [...] 6820231428
5.) http://www.newegg.com/Product/Prod [...] 6813128527
6.) http://www.newegg.com/Product/Prod [...] 6819115078
7.) http://www.amazon.com/Hitachi-Desk [...] 52&sr=1-14
8.) And an unspecified DVD drive
My main reason for a new build is for gaming and playing games like Napoleon:Total War and the like.
OS: Windows Vista/XP/7
Processor: 2.6 GHz Dual Core
CPU Memory: 2 GB RAM (XP), 4 GB RAM (Vista/Windows 7)
Graphics: 512 MB DirectX 9.0c shader model 3 compatible GPU DirectX®: DirectX 9.0c
Hard Drive: 21 GB free space
I'm not a Ultra Mega graphics person but I just wanted something that could play it without any lag.
Good graphics to me are a nice bonus not a deal breaker.
My absolute budget is $500 for a whole computer.
I don't know anything about computers and am being told different things by everyone here.
Reply to jackpapa
Well for you, my advice is to not skimp on your processor, go with an i7, you wont need more than 2 gigs of ram..
Reply to thespieler
- 0 +
Ok, I was in your other thread, and here's the build I came up with:
HITACHI HDS721050CLA362 (0F10381) 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:HDS721050CLA362
Item #:N82E16822145299
$79.99 $79.99
Hard drive prices are all bad now. The only way to get cheaper is to go for used or recertified.
AMD Phenom II X3 720 Black Edition Heka 2.8GHz Socket AM3 95W Triple-Core Processor HDZ720WFK3DGI - OEM
Model #:HDZ720WFK3DGI
Item #:N82E16819103652
$74.99 $74.99
Doesn't come with a HSF, but may unlock to X4, and will overclock easily because it's a BE.
NZXT Source 210 S210-001 Black “Aluminum Brush / Plastic” ATX Mid Tower Computer Case
Model #:S210-001
Item #:N82E16811146075
$39.99 $39.99
Looks decent, and has free shipping. That alone can add $10 or more to the price of a case.
Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler, free TX-2 Thermal Paste Included Inside
Model #:CR-CCTF
Item #:N82E16835207004
$24.99 $24.99
Most any 120mm HSF should be fine. This one is inexpensive and performs well.
ASRock 870 Extreme3 R2.0 AM3+ AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Model #:870 Extreme3 R2.0
Item #:N82E16813157272
$89.99 -$10.00 Instant $79.99
I haven't used this specific one, but other ASRock boards I've bought have all performed well. It has USB3.0 and SATA 6Gb/s.
Antec EarthWatts Green EA-430D Green 430W Continuous power ATX12V v2.3 / EPS 12V 80 PLUS BRONZE Certified Active PFC Power ...
Model #:EA-430D Green
Item #:N82E16817371034
Mail in Rebate
$59.99 -$10.00 Instant $49.99
The Earthwatts PSUs are all solid, quiet, and efficient. I've mostly used the 380W ones, but there's a better deal on this one ATM.
PowerColor AX6770 1GBD5-H Radeon HD 6770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card
Model #:AX6770 1GBD5-H
Item #:N82E16814131434
Mail in Rebate
$114.99 -$5.00 Instant $109.99
Keeping your budget in mind, I chose this card as being strong enough to play any game. If your budget has wiggle room, this is one of the first places to improve this build, such as to a HD6850.
G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-10600CL9D-4GBNS
Model #:F3-10600CL9D-4GBNS
Item #:N82E16820231394
$20.99 $20.99
I buy mostly G.Skill now because I've never had a DOA or RMA on it. Get an 8GB kit if your budget has wiggle room, but this is still enough.
Sony Optiarc CD/DVD Burner Black SATA Model AD-7261S-0B LightScribe Support - OEM
Model #:AD-7261S-0B
Item #:N82E16827118040
$19.99 $19.99
One optical drive is much like another, but this one has Lightscribe.
Subtotal: $500.91
There are also a couple of rebates in there if you play that game and win. For the money, this will do well, but another $50-$100 would make a substantial difference. You might even manage a SB build, but current HDD prices don't appear to allow that on your initial budget.
Of course, this assumes you already have a license for Windows. If not, it makes a big difference.
Reply to jtt283
Ok lets start with this with your budget i don't think Intel is the way to go. They may be faster than amd but still you can get a amd quad for the same price that will beat out the dual. With that said let me see if i can put something better together.
Keep the case that's a good deal. http://www.newegg.com/Product/Prod [...] 6811129066
Mobo: http://www.newegg.com/Product/Prod [...] 6813138283
Ram: http://www.newegg.com/Product/Prod [...] 6820231428
CPU: http://www.newegg.com/Product/Prod [...] 6819103995
PSU: http://www.newegg.com/Product/Prod [...] 6817822016
HDD: http://www.newegg.com/Product/Prod [...] 6822145299
CD: http://www.newegg.com/Product/Prod [...] 6827135204
Graphics: http://www.newegg.com/Product/Prod [...] 6814131440
Well that's what i got total is about $500. not including rebates.
Message edited by nutmanmatt on 12-09-2011 at 08:01:53 PM
------------------------------ FX-4100@ 4.7GHz/Biostar TA990FXE/ 8 GB DDR3@ 2100MHz/GTX 460 1G@ 850/1925/1195/ 500 GB hardrive/OCZ StealthXStream 600 watt powersupply/
Reply to nutmanmatt
A i7 on a $500 budget? Ya right that's crazy
Reply to nutmanmatt
For the game hes talking about, he should skimp more on graphics than on his processor. A phenom x3 wont cut it
Reply to thespieler
Ah! Thank you Jtt283.
I have Windows XP Pro if that is enough.
I appreciate your help but I noticed that some of those components are not as high as others I posted. (2.8ghz processor and 430W PSU instead of 500W psu and 3.0ghz.) Although I believe others have told me that their not really that powerful.
But is your build the best? Could I play the above game specs without lag?
Sorry I've just been researching and discussing for months now. And everyone's advice is contradicting each other.
Reply to jackpapa
A i7 is way more than needed for total war and that would take up to much of his budget a Phenom x4 or even a x3 will be fine. I played total war on a dual just fine
Reply to nutmanmatt
Oh! Take me a while to reply to everyone.
Reply to jackpapa
Every one has their own idea on a good computer build. for example my build has a better cpu and jt has a better graphics card. Both would play total war it just comes down to what you want.
Reply to nutmanmatt
Do I need a i7? Is is good to skimp on graphics? Or which is more important? Graphics or processor? :??:
Reply to jackpapa
No you don't need a i7 it is way out of your budget. For gaming you usually want better graphics however with total war it is hard on the cpu to so you have to balance them.
Reply to nutmanmatt
Oh! Okay well....Like I said I would rather it was a lagless experience than just Ultra mega graphics. Good graphics are a nice bonus, not a deal breaker.
By lagless in total war I mean when you pan the camera left/right etc....to survey things without freezing or slowing down.
Reply to jackpapa
Ya both mine and jts build should give you a lag free experience it just comes down to what you want. jts will be able to do better graphics while mine will have a faster cpu. That means that if you ever want to do more graphically advanced games like mw3 or what not jts is the way to go. However mine will be faster with everyday tasks and games like total war or games similar to it that deal with lots of units at the same time.
Reply to nutmanmatt
- 0 +
Do NOT buy a Diablotek PSU-shaped object! If you want fireworks, you should be able to find them for a lot less. More seriously, a Diablotek "500W" PSU "may" be capable of half that, for a while. A real PSU, such as an Earthwatts, will be capable of more than what is on its label (although I'm certainly not recommending they be run that hard).
Considering that a miserable little Athlon II X2 can play any game (though some new ones like Skyrim not very well), to say a Phenom II X3 cannot handle an older game like Napolean: Total War makes no sense.
Reply to jtt283
Wow! Both seem really awesome, but I think I like yours better nutmanmatt.
I prefer faster tasks and more units. So If I understand correctly if I go with your build than I'll be able to play Total War games like Napoleon?
And maybe a few years down the line could I upgrade the video card for better graphics?
And/or could I go with your build but use jts video card?
So confusing...
Reply to jackpapa
Could I use nutmanmatt's build with an earthwatts PSU? Is it more expensive and/or compatible with his build?
Do you have a link?
Hmm....:??:
Reply to jackpapa
So confusing...
Haha ya it is confusing at first.
Yes if you can afford to put jts graphics card in my build it would be a pretty good computer. Or you can just put a new graphics card in later.
Reply to nutmanmatt
I have never had any problems with Diablotek i don't know if you have had problems with them but they run fine with me. Yes i would put something better in but im trying to stick to the $500 budget.
Reply to nutmanmatt
Ah! Okay thanx! So that just leaves the PSU then...
Is Diablotek really as bad as jtts says it is?
Reply to jackpapa
- 0 +
The older Biostar A780L3B does not include Zosma on its CPU Support list: http://www.biostar-usa.com/app/en- [...] p?S_ID=536
Even though it is 95W, it may or may not work. Check first before you go that way.
Reply to jtt283
- 0 +
Yes, Diablotek is that bad. Jonnyguru and HardwareSecrets have both reviewed some. They tend to blow up, well under their rating. Jonnyguru had some expensive test equipment damaged by one of them.
A quality modern PSU has full range active PFC (no little voltage switch) and some level of 80+ certification for efficiency. Seasonic, Antec, Corsair, XFX, and Enermax/LEPA are among the better brands. Diablotek, Apevia, Logisys, and anything else with "max" in its name are all junk. OCZ is hit or miss, but generally not bad. Except at the extreme high end, Coolermaster ranges from "polished turd in a box" (per HardOCP) to a notch or two above junk.
Reply to jtt283
I don't think that will be a issue im pretty sure it will work
But just to be safe ill switch it to this http://www.newegg.com/Product/Prod [...] 6813138283
Reply to nutmanmatt
Hmm Well what would you recommend as a substitute?
I"m wanting this build but I guess It would do me no good to get a psu that catches on fire.
Reply to jackpapa
Haha as i said i have never had problems.
http://www.newegg.com/Product/Prod [...] 6817371048
This is a good one but as you can see we are going past your $500 budget little by little.
Reply to nutmanmatt
Are u all nuts? The builds u suggest are totally unbalanced. My build is way better in any adpect. I don't have login in uk forum. But it's madchemist if it helps. Ill just continue on original post
Reply to madchemist83
Or I guess I have :-)
Wow mad way to jump in and bash our builds. Suggest something better than huh.
Reply to nutmanmatt
Wait,wait,wait, So Do I have this right?:
1.) Your build except...
2.) http://www.newegg.com/Product/Prod [...] 6817371048 (this psu.)
3.) http://www.newegg.com/Product/Prod [...] GB%20128-b (jtt's video card. )
Do we need to replace the mobo to this as well?
hmmm.... :??:
Oh! didn't see you there madchemist.
Message quoted 1 times
Message edited by jackpapa on 12-09-2011 at 08:15:30 PM
Reply to jackpapa
- 0 +
The builds we've suggested need no more than a quality 350W-400W PSU. You could put the 430W Earthwatts into nutmanmatt's build with the amended mobo choice. I still think you want a stronger GPU though. If you do want to get something weaker than a HD6770, at least make sure it has GDDR5, not DDR3. This HD6670 is $93 shipped, and includes a $40 software coupon (basically a free game): http://www.newegg.com/Product/Prod [...] 6814102935
Edit: ...with the amended mobo choice...
Edit2: further clarification, a 380W Earthwatts PSU would run that build with a HD6850 GPU 24/7 with no trouble at all, so the 430W version offers plenty of reserve capacity if you're only using a HD6770 or HD6670.
Message edited by jtt283 on 12-09-2011 at 08:19:58 PM
Reply to jtt283
hmmm.... :??:
Yes (cant see psu says page unavailable but if its the antec one i recommended yes)
that would be better than mine and jts as it has jts graphics and my cpu along with a good psu.
Reply to nutmanmatt
Yes a 350w or 400 would work but if he upgrades his graphics card in the future it might start to lack a little. Also i like to have more than enough power available not just enough.
Reply to nutmanmatt
So are we all in agreement for this build then?
1.) Case: http://www.newegg.com/Product/Prod [...] 6811129066
2.) MOBO: http://www.newegg.com/Product/Prod [...] 6813138283
3.) RAM: http://www.newegg.com/Product/Prod [...] 6820231428
4.) CPU: http://www.newegg.com/Product/Prod [...] 6819103995
5.) PSU: http://www.newegg.com/Product/Prod [...] 6817371048
6.) HDD: http://www.newegg.com/Product/Prod [...] 6822145299
7.) CD/DVD: http://www.newegg.com/Product/Prod [...] 6827135204
8.) Graphics: http://www.newegg.com/Product/Prod [...] GB%20128-b
Is this the culmination of what we discussed? (the best of our opinions?)
Or am I overlooking something?
I'm just trying to establish the best of the discussion. I'll need to figure out if my budget will cover this a little more.
hmmm...
EDIT: here's the case link again: http://www.newegg.com/Product/Prod [...] 6811129066
Message edited by jackpapa on 12-09-2011 at 08:51:36 PM
Reply to jackpapa
hmmm...
Yup looks pretty good expect i noticed one issue.......The case says it it only supports supports ATX boards......Hate when they make mid cases that don't support micro!
This case is the same price and pretty similar though(and it supports micro boards)
http://www.newegg.com/Product/Prod [...] 6811147153
Reply to nutmanmatt
My build is original build .. it's cheaper then ur other builds and is a better performer
Biostar mobo is of a low quality
my i3-2100 build will wipe the floor with ur AMD builds
- 0 +
"Well for you, my advice is to not skimp on your processor, go with an i7, you wont need more than 2 gigs of ram.."
This is a quote, not my opinion, if this is not clear. But it is nonsense.
I can't review your build as I will not click on every link to see what you're considering. Please add description.
That said, I did look at your RAM choice and that's good.
------------------------------ AMD FX4100 | Xigmatek Gaia | FSP Bluestorm 500w Bronze | ASRock 970 Extreme 3 | 8Gb Patriot ram | XFX HD6770 1Gb
20" Monitor 1680x1050
Reply to longpig
i will not click on every link but I'll suggest i7 ?
weak :)
Okay so with that as the case I need to figure out what I can skimp on.
Reply to jackpapa
If you skimp on anything now you would have to give up ether the cpu or graphics card for cheaper ones i would really just leave it as it is.
Reply to nutmanmatt
Well I put in that build and It came out as(with shipping,taxes,etc...) $614.01 (without rebates)
I'm going to borrow money from someone who is very understanding but I'm worried about saying $600 instead of $500 dollars. I'm also going to college and buying books so the leftover money I could use as well so well see..
Hmmm...
Message edited by jackpapa on 12-09-2011 at 09:19:18 PM
Reply to jackpapa
- 0 +
weak :)
Mate, if you want to get into it ok. But I was quoting an earlier piece of nonsense. I'm trying to remain polite here.
I wasn't suggesting i7 for this, merely pointing out what I consider bad advice . If you want to flame me, go ahead, but read the thread first....
(And imagine how much editing has gone into this post)
Reply to longpig
ehh .. my build is $465 ?? and what's wrong with it ?
Hmmm...
Well if you want to go back to $500 than we will be right back where we started with jts build or mine. Your choice we did go over the budget by allot though..........you could go back to jts x3 cpu to save some money if you really need to.
Reply to nutmanmatt
Sorry how out of control this thread got.
So If that build doesn't fly, then whats the next best build with regards to performance over graphics.
Reply to jackpapa
I've never built a pc so take this for what it's worth. But I would consider an A series processor. They have good starting graphics that you can add a card to later. So even if it costs more you don't have to buy a graphics card. Just definetely go with 6gb of ram. I have an A6 in my laptop and love it. For the price to be able to play games it was worth toning down the graphics on intense games. So the best definentely not but I would think if you get an A8 with 6gb of ram and drop a card in later you could rock pretty good.
Reply to BonesofTibado
i guess if you can downgrade the graphics. to this maybe
http://www.newegg.com/Product/Prod [...] 6814129187
save you a bit of money
also change psu
http://www.newegg.com/Product/Prod [...] 6817371034
save you even more.
Reply to nutmanmatt
^ there is a reason u never built a pc :)
Original build is cheaper and better .. HELLO
also change psu
save you even more.
So a possible backup build would be what I posted but with those components? Would I still need the micro MOBO and micro compatible case?
Reply to jackpapa
Yes after studying it for a second i did notice that.
Reply to nutmanmatt
Previous
1 2 3
There are 1515 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Gigabyte z77x not working with corsair tx750?
By smorizio, 5 hours ago:
[quotemsg=2611689,1,1216211]hi guys i need some help, im not getting any power to the...
Best offers
Top experts
