Cooler Master CM-690 Please HELP!!
Building my first PC and running into real problems with this case and need help!
I bought an SSD drive but have no idea how to mount it into this case its so confusing and the manual is useless!
Can someone please tell me if this case allows SSD cards
2 answers Last reply
More about cooler master help
  1. I believe this is the 690? http://www.coolermaster.com/upload/product_feature/CM690II-Adv_01.jpg
    It shows a SSD slot, in the picture.
  2. The original 690 does not have specific 2.5" mounting spaces. If your SSD came with a 3.5" mounting bracket (many do), put it in that, then mount the bracket in one of the 3.5" frames in the CM.
    If all else fails, you can zip-tie the SSD into one of those frames. They do not vibrate, so perfect mounting is non-essential.
Power Supplies Cooler Master Cases SSD Components
