Using headphones+speakers for djing with asus 5.1 sound card
Hello everyone,
i have a ASUS XONAR_DG 5.1 Channels PCI Interface Xonar DG Sound Card and im trying to figure out how i can use the front port audio i have connected to it along with my rear port audio. i have logitech Z506 5.1 speakers connected in the rear, and normal over the ear headphones for the front port. I need to be able to recognize the two as different outputs for Virtual DJ, but have the ability to use them at the same time. I am on Windows 7 x64 bit.
Thanks to anyone who posts a reply to help me.
1 answer Last reply
More about using headphones speakers djing asus sound card
  1. All you do is take the front panel plugs that are connected to your motherboard and connect them to the sound card instead. Now your front panel will use the sound card.
Sound Cards Asus Components
