Dongle problems please help.
Archived from groups: alt.cellular.bluetooth (More info?)
I have a prodigy bluetooth usb dongle and cant get it to work at all!
ive installed the software that came with it but still no look,when i
insert the dongle it says 'On of the USB devices attatched to the
computer has malfunctioned,windows does not recognise it'.
Can any one help.
Leetooth
3 answers Last reply
More about dongle problems help
  1. Archived from groups: alt.cellular.bluetooth (More info?)
    OK. Prodigy is the brand, I take it. But who is the actual manufacturer?
    And which version of Windows? Did you plug in the dongle, then run the
    installation, install & plug it in at an appropriate point during
    installation, install then plug in & reboot, or what? We need more info in
    order to help.
    I know with my Targus branded Widcom dongle in XP Home, I needed to install
    & let XP do its thing, then uninstall the XP drivers & manually force the
    installation of the drivers from my CD.
    Bill K
  2. Archived from groups: alt.cellular.bluetooth (More info?)
    > order to help.
    > Bill K
    Here and several others under the NG news.sf.sbcglobal.net many times I
    see a reply quoting the original msg, but have not seen the original msg.
    Are these original msgs in other NG's and if so, why is the reply seen
    here? (this one is seen in alt.cellular.bluetooth.
    Miles
  3. Archived from groups: alt.cellular.bluetooth (More info?)
    Sounds like either your news server or your newsreader has problems. The
    message I replied to is in this NG. And, according to the header, only in
    this NG.
    Bill K
Bluetooth USB
