Will 250 watt work for 300 watt requirement
Hello,
I have a pc with 250 watt power supply, I want to but this video card that requires 300 watt minimum, can I use the video card
10 answers Last reply
More about will watt work watt requirement
  1. We need more info, tell us your FULL specs and budget first...
  2. You will probably wind up blowing the power supply and when that goes it will most likely take out the video card as well!
    Get a nice 400w ps for 20 bucks or jump on craigslist and find something local.
    If you do end up testing it, keep an eye on the PSU heat or for any random reboots means no go!
  3. Sorry, but a 20 dollar psu is crap. The psu is one of the most important components of your pc which has to deliver reliable and stable power to your system. Don't go cheap on psu.
    I actually have a few Corsair 430w power supplies which are not crap at all but when they go on sale they are cheap.
    $24
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
    Yes your PSU is very important but I imagine if someone is looking to use a 250w power supply instead of buying a 300w then the $24 power supply is exactly what they need!
  5. Wow, that is a good AND cheap psu, i stand corrected, sir. :D
  6. When you post this
    It does tend to infer that you are suggesting something cheap and generic.
    The PSU you linked to is obviously on special offer and you would usually expect to spend around its usual retail price to get a PSU that would be considered adequate in the 400 Watt area.
    So the inference that you can get a reputable PSU for the special offer price you linked to is at best misleading and borderline irresponsible.
    robjordy is 100% correct, a cheap PSU is a cheap PSU and as such should not be touched with a barge pole.
    Yes the PSU linked to is a reputable brand and would be up to the job, assuming you knew about it before hand and didn't run a search to back up what you were saying i suggest it would have been easier all round had you linked to the PSU in question in the first place.
    Back to the case at hand.
    What is the card ? and what is the PSU ?
    Card manufacturers over quote the needed power and some like Dell's PSU's are actually quite under rated.
    Mactronix :)
  7. Mmmmm, i should have thought about that, it's still early here, not completely awake yet. Thanks Mac.
    So ; I don't stand corrected ! :kaola:
  8. No you most certainly don't
    Mactronix :)
  9. The correct term would be quality but inexpensive!
  10. No modern PSU will blow. They just shutdown or refuse to start.
    Maybe a faulty one but that happend to all brands or rated capacities
Graphics Cards Power Supplies Graphics Product
