Running IP camera off batteries
brandonyoung26
Hi,
I am working on a project for my computer science degree and have run into a problem.
My project is to control a small chicle over the internet. Currently I have it all working except the fact that I am unable to power my IP camera by a battery pack.
On the actually camera it states DC 5V and on the power adapter it states OUTPUT 5V===2000mA
This is what I have bought so far
5v regulator
http://www.radioshack.com/product/in...ductId=2062599
Battery holder
http://www.radioshack.com/product/in...ductId=2062253
Rechargeable batteries
http://www.walmart.com/ip/Energizer-...eries/10242692
If anyone has any ideas how i can get this IP camera running off batteries then please let me know.
Thanks in advance.
ngoy
139
Your Ic only supports 1A. Your camera need 2A.
You need something like this:
http://www.nteinc.com/specs/1900to1999/pdf/nte1934.pdf
you will need to give it more than 5V to ensure proper regulation, this one has a minimum of 8, you might get by with 7.2V (6 1.2V rechargeable cells) but 7 would make it up to spec at 8.4V (wired in series). May need a heat sink on the ic. Theoretical 100% efficiency would give you 3360 mAh at 5V I think? or 1.68 hours of runtime if it actually pulls 2A@5V. so maybe an hour and a half realistically.
I only do hobby electronics, there are plenty of people here who know more than I do. Also, there are other sites that are dedicated sites for these things.
Be careful, it is easy to fry stuff when you make custom power supplies....
